Page 1 of 1
Getting "Unable to extract header from stream, retrying
Posted: Mon Apr 26, 2004 4:32 pm
by dave_d
I've got this DLink DCS1000 camera. I tried to get it to work with a 0.9.n version of ZM but failed miserably. The posts at the time rather indicated that failure was more common than success and so I decided to wait a while before continuing with the surveillance project I was working on. Recent posts seem to indicate that most of the IP camera streaming problems had been solved. So, I rebuilt the Slackware box, got the latest 1.19.2 and built everything from scratch. I hooked up the DCS1000 and yes! - a video stream appeared. :D I used i/p address, port = 80, source = /video.cgi and a picture size of 240X320.
I then added another camera running from a video card - and lost the i/p camera stream. :cry: Since then I've tried everything including removing the database and rebuilding all ZM fom scratch. No more i/p camera stream!! All I get (occassionally and if I'm quick enough to #killall -USR1 zmc) is the error message "Unable to extract header from stream, retrying".
Can anyone shed any light here?
Regards,
Dave
Posted: Tue Apr 27, 2004 9:12 am
by dave_d
Well, I managed to get it all working again - but I don't really have a good explanation of what happened. Here's what I did ...
1. remove the zm database
2. Apply the zm-1.19.2 patch
3. perl zmconfig.pl
4. rebuild the zm database
5. perl zmconfig.pl -noi
6. restart zm
7. check the camera and set the date/time (was a long time in the past)
8. make a monitor as described in the previous post
All works!!!!
The only other thing I found was a strange error message in the apache error log. The lines are:
[Mon Apr 26 17:36:53 2004] [error] [client 192.168.40.2] File does not exist: /var/www/htdocs/zm/com/charliemouse/cambozola/ViewerBeanInfo.class
[Mon Apr 26 17:36:53 2004] [error] [client 192.168.40.2] File does not exist: /var/www/htdocs/zm/com/charliemouse/cambozola/Viewer$COMClassObject.class
[Mon Apr 26 17:51:07 2004] [error] [client 192.168.40.2] File does not exist: /var/www/htdocs/zm/com/charliemouse/cambozola/Viewer$COMClassObject.class
[Mon Apr 26 17:55:10 2004] [error] [client 192.168.40.35] Premature end of script headers: /var/www/cgi-bin/zms
[Mon Apr 26 17:56:37 2004] [error] [client 192.168.40.2] File does not exist: /var/www/htdocs/zm/com/charliemouse/cambozola/Viewer$COMClassObject.class
You can see from the time stamps that these occurred during various attempts I made yesterday to get things going. I have no idea what these error messages indicate. Most puzzling is the fact that I've never had a directory called com/charliemouse!!!!
Phil ... any comment?
Regards,
Dave
Posted: Tue Apr 27, 2004 4:15 pm
by zoneminder
I think the
error is just something Java'y. It's appending the class path onto the web path or something like that. I don't know a huge amount about the Cambozola applet but if it's working then that's the main thing. Did you rebuild it yourself or just use a ready made .jar file?
Phil,
Posted: Thu Apr 29, 2004 4:57 pm
by dave_d
Hi Phil,
I used the Cambazola version I got from your web site eons ago - 0.22, IIRC!
Dave
