Console picture does not enlarge ( New user)
paul21019
Post by paul21019 »
In console i get the current picture from my camera in a icon type view , when i hover - the picture enlarges and shows live , when i double click the picture goes to a bigger screen but then there is a blank screen ( looks like a movie to be played) , when I goto Montage - same thing , if I choose Montage review - the live picture is there
Is this normal ? I an on continuous record
Capturing
Analysing: Always
Recording: Always
ZM Capture.JPG (14.95 KiB) Viewed 3024 times
Re: Console picture does not enlarge ( New user)
I had the same issue on 5 SEP. A "fix" was released on 6 SEP. Make sure you are on the latest release.
You will have these problems on development versions!
