First...Thanks to Phillip for a great Linux CCTV solution.
Here is the problem:
I just finished installing Zoneminder on a Redhat9 Disto. Followed the instructions in the README and everything went relatively smooth. Usually able to solve most issues by checking this forum or doing a google search.
I'm at the point where it is now telling me to "point my browser to zm.php and off you go" Well...i'm not off the ground yet.
When I point my browser to this location all I get is a blank page. No ZM console. I have PHP installed. Using browser Mozilla 1.4.2
How can I be sure that the Zoneminder services are running? I'm a bit of a Linux newbie, forgive me if I'm missing something completely obvious.
Thanks for your help.
Zoneminder console
- zoneminder
- Site Admin
- Contact:
I was able to to view the page source as well as do a 'PHP zm.php' from the ZM directory.
Here is what emerged:
When running PHP zm.php it said on one line: "<script language="JavaScript">"
Could it be as simple as having java installed and enabled? If so...oops.
If I'm way off base I find out in a bit....thanks
- zoneminder
- Site Admin
- Contact:
This is what I see when I run zm.php from the command line:
X-Powered-By: PHP/4.2.2
Expires: Mon, 26 Jul 1997 05:00:00 GMT
Last-Modified: Sat, 01 May 2004 20:16:56 GMT
Cache-Control: no-store, no-cache, must-revalidate
Cache-Control: post-check=0, pre-check=0
Pragma: no-cache
Content-type: text/html
<html>
<head>
<title>ZM - Console</title>
<link rel="stylesheet" href="zm_styles.css" type="text/css">
<link rel="shortcut icon" href="favicon.ico">
<link rel="icon" type="image/ico" href="favicon.ico">
window.resizeTo( 720, 540 );
function newWindow(Url,Name,Width,Height)
var Name = window.open(Url,Name,"resizable,width="+Width+",height="+Heig
ht);
function scrollWindow(Url,Name,Width,Height)
var Name = window.open(Url,Name,"resizable,scrollbars,width="+Width+",he
ight="+Height);
function configureButton(form,name)
var checked = false;
for (var i = 0; i < form.elements.length; i++)
if ( form.elements.name.indexOf(name) == 0)
if ( form.elements.checked )
checked = true;
break;
form.delete_btn.disabled = !checked;
function confirmDelete()
return( confirm( 'Warning, deleting a monitor also deletes all events an
d database entries associated with it.\nAre you sure you wish to delete?' ) );
window.setTimeout( "window.location.replace('')", 300000 );
</script>
</head>
<body scroll="auto">
<table align="center" border="0" cellspacing="2" cellpadding="2" width="96%">
<tr>
<td class="smallhead" align="left">Sat 1st May, 2:16pm</td>
<td class="bighead" align="center"><strong><a href="http://www.zoneminder.com" t
arget="ZoneMinder">ZoneMinder</a> Console - <a href="javascript: newWindow( '?vi
ew=state', 'zmState', 300, 120 );">Stopped</a> - <a href="javascript: newWindow(
'?view=version', 'zmVersion', 320, 140 );">v1.19.2</a></strong></td>
<td class="smallhead" align="right">Load: 0.27 / Disk: 14%</td>
</tr>
<tr>
0 Monitors</td>
<td class="smallhead" align="center">Configured for <a href="javascript: ne
wWindow( '?view=bandwidth', 'zmBandwidth', 200, 90);">low</a> bandwidth</td>
<td class="smallhead" align="right"><a href="javascript: newWindow( '?view=optio
ns', 'zmOptions', 760, 480 );">Options</a></td>
</tr>
</table>
<form name="monitor_form" method="get" action="" onSubmit="return(confirmDelete(
<input type="hidden" name="view" value="console">
<input type="hidden" name="action" value="delete">
<tr><td align="left" class="smallhead">Id</td>
<td align="left" class="smallhead">Name</td>
<td align="left" class="smallhead">Function</td>
<td align="left" class="smallhead">Source</td>
<td align="right" class="smallhead">Events</td>
<td align="right" class="smallhead">Hour</td>
<td align="right" class="smallhead">Day</td>
<td align="right" class="smallhead">Week</td>
<td align="right" class="smallhead">Month</td>
<td align="right" class="smallhead">Archive</td>
<td align="right" class="smallhead">Zones</td>
<td align="center" class="smallhead">Mark</td>
</tr>
<tr>
<td colspan="2" align="center">
<input type="button" value="Refresh" class="form" onClick="javascript: location.
reload(true);">
</td>
<input type="button" value="Add New Monitor" class="form" onClick="javascript: n
ewWindow( '?view=monitor', 'zmMonitor', 360, 300);">
</td>
<td align="right" class="text"><a href="javascript: scrollWindow( '?view=events&
page=1&filter=1&trms=1&attr1=Archived&val1=0', 'zmEvents', 720, 480 );">0</a></t
d>
page=1&filter=1&trms=2&attr1=Archived&val1=0&cnj2=and&attr2=DateTime&op2=%3e%3d&
val2=-1+hour', 'zmEvents', 720, 480 );">0</a></td>
val2=-1+day', 'zmEvents', 720, 480 );">0</a></td>
val2=-1+week', 'zmEvents', 720, 480 );">0</a></td>
val2=-1+month', 'zmEvents', 720, 480 );">0</a></td>
page=1&filter=1&trms=1&attr1=Archived&val1=1', 'zmEvents', 720, 480 );">0</a></t
d>
<td align="right" class="text">0</td>
<td align="center"><input type="submit" name="delete_btn" value="Delete" class="
form" disabled></td>
</tr>
</form>
</table>
</body>
</html>
Pragma: no-cache
<html>
<head>
ht);
ight="+Height);
checked = true;
break;
</script>
</head>
<tr>
</tr>
<tr>
0 Monitors</td>
</tr>
</table>
</tr>
<tr>
reload(true);">
</td>
</td>
d>
d>
</tr>
</form>
</table>
</body>
</html>
Sorry Philip...it was something completely obvious.
I created a test.php file and dumped it into the DocumentRoot to make sure apache and PHP were working. The test php file worked perfectly. That's when I realized I did not edit the httpd.conf file to tell it where the ZM files are.
Zoneminder is up and running perfectly now.
