There are events in the selected time range, but when the timeline marker passes over them or I move it manually, the video display shows nothing, always displaying the text 'No Data'.
The events can be played by going to each one individually, meaning the video exists and is playable, but for some reason, not through the montage review.
Any idea why?
URL -> index.php?
view=montagereview
&filtering=
&MonitorName=
&Source=
&MonitorId=1
&minTime=2024-09-27+01%3A52%3A29
&maxTime=2024-09-27+09%3A52%3A28
&archive_status=
&fit=1
&live=0
Montage review does not play event videos
- zoneminder.jpg (189.43 KiB) Viewed 647 times
Re: Montage review does not play event videos
Montage Review has been flawed for a long time. I've put a lot of work into it in 1.37, but am unlikely to back port it.
I will take a look and see if something can be fixed quickly.... but you might be better off switching to 1.37.
