Page 1 of 1
Trouble installing zm on debian.
Posted: Sun Sep 29, 2024 7:16 pm
by Birdman3131
https://wiki.zoneminder.com/Debian_12_B ... and_1.37.x
So I followed the guide here untill I got to the line "Old procedure retained for reference"
Google implies that I should see it at 127.0.0.1/zm but that brings up "The requested url was not found on this server".
What am I missing? Im not stuck on debian. This is a vm I just spun up. Ran Zone minder ages ago and wanted to give it a go again.
Re: Trouble installing zm on debian.
Posted: Sun Sep 29, 2024 8:24 pm
by blaczero
Does
http://127.0.0.1 work? Without the /zm?
Posted: Sun Sep 29, 2024 9:09 pm
by Birdman3131
brings up a basic apache default page
Posted: Sun Sep 29, 2024 11:40 pm
by blaczero
did you a2enconf zoneminder?
also, does /usr/share/zoneminder/www have stuff like index.php in it?
Posted: Sun Oct 13, 2024 3:12 am
by Birdman3131
blaczero wrote: ↑Sun Sep 29, 2024 11:40 pm
The script on that guide does a2enconf zoneminder
It has some stuff but the index/php is in a www subfolder
Posted: Sun Oct 13, 2024 1:05 pm
by bbunge
I will spin up a test machine and run the install to see if there are any bugs.
Stay tuned...
Posted: Sun Oct 13, 2024 1:38 pm
by bbunge
The install worked OK for me. I did not run it on a VM and did not try to access Zoneminder using a loopback (127.0.0.1) IP address.
Posted: Sun Oct 13, 2024 11:35 pm
by Birdman3131
bbunge wrote: ↑Sun Oct 13, 2024 1:38 pm
So started going through the script line by line and you were correct on the a2enconf zoneminder part. It was returning a command not found.
Looking around I found this and used the command
su -
and then ran through and everything worked.
https://stackoverflow.com/a/63411977
Thanks for all the help.
