Zoneminder 1.36x on FreeBSD 14.0 issue
Posted: Tue Oct 01, 2024 6:56 am
I just upgraded a working instance of zoneminder-1.36.33_2 to zoneminder-1.36.33_3 and from all the sudden it's not able to access the DB with error:
geometry dash lite
I checked my DB grants again and everything seems fine to me:
Does any one you run Zoneminder on FreeBSD and got the same issue? Any advice?
Thanks in advance!
geometry dash lite
Unable to connect to ZM db using dsn mysql:host=localhost;dbname=zm;charset=utf8
SQLSTATE[HY000] [1045] Access denied for user 'zmuser'@'localhost' (using password: YES)
| Grants for zmuser@localhost |
| GRANT USAGE ON *.* TO `zmuser`@`localhost` |
| GRANT ALL PRIVILEGES ON `zm`.* TO `zmuser`@`localhost` |
Thanks in advance!
