ZM-compatible 360°C PoE PTZ: advice?
aag
Post by aag »
I wish to mount a 360° PoE camera on the roof of my house.
  • It should be compatible with ZoneMinder.
  • It should be wired with just one cable, hence PoE.
  • It could be a PTZ, but I would prefer several sensors for panoramic view, because the roof is not easily accessible and no moving parts means less chance of failure.
  • My budget should not exceed $800 if possible, but could go up to 1K if there is a good reason.
Any advice? Thanks in advance!
