Zoneminder setup
Daavey
Zoneminder setup
Post by Daavey »
I have an ancient Dell PC, running Ubuntu 8.04 and Zoneminder. It works fine. Iy is time tom replace the ancient Dell with a new PC, which I have purchased. It is running ZM 1.36.34. I have a Euresys Picolo PCIe capture card, which uses the bt878 chip. I have managed to get everything working except for the actual image, which scrolls around instead of remaining still. The log shows no problem, it is capturing the image, but I can't see anything. I have tried every de-interlace option available, the H x W are compatible, but I can't get over the final hurdle.
Any help would be appreciated, I am just going round in circles.
Quantum
Re: Zoneminder setup
Post by Quantum »
Ditch the analog stuff immediately, if not sooner.
Amazing night color, when we can't see. https://www.dahuasecurity.com/
Turret cameras.
Daavey
Post by Daavey »
Thank you, Carrson, I know that already. What I don't know is how to stop it. Eursys only supports their own software, which needs a
more expertise than i will ever possess to make function.
