newbie question on SourceSecondPath
alanm
Post by alanm »
Hi I'm a newbie and have v1.36.33 running in a Proxmox container with 8cores/16G.
I'm created monitors for 4 Anpviz IP cameras (3 5MP, 1 4MP) and havent had issues
but when I try modect mode, the load goes way and I'll started getting the "Can't keep up ..." messages
I beleive thie issue is that I'm trying to analyze too much data at that
abd that the general advice seems to be to create a substream and only analythe the substream.
My Camera ui shows a substream options but how do I know what the url is of teh substream.
My working main stream url is. rtsp://<user>:<pass>@<ip-addr>:554/live/mpeg4
which I got from https://wiki.zoneminder.com/Hardware_Compatibility_List
Screen Shot 2024-10-31 at 18.11.54 PM.png (74.71 KiB) Viewed 1440 times
Re: newbie question on SourceSecondPath
SourceSecondPath is for a separate audio stream. Someday it might be for the substream, but thus far has not been implemented.
Google for linked monitors.
1.36.33 is old and has security vulnerabilities. I would encourage you to upgrade.
1.37 series has more options for using less cpu.
Andyrh
Post by Andyrh »
You should also consider a reduced frame rate. Security video is frequently 10FPS and lower. TV shows are 24FPS.
An 8MP camera @ 8FPS doing modect takes ~50% of one of my Xeon threads. That may help you.
Another thing that will help later, increase your key frame rate. My key frames are once a second.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
alanm
Post by alanm »
So is this how it's supposed to work?
The lowres mon is in modect, the hires mon in monitor mode.
When movement is detected in lowres, the linked monitor starts to record?
I have:
"left" monitor is streaming 3072x2048 and
"left_lowres" monitor is streaming at 704x576 D1 PAL
left (hi res) monitor has as a linked (low res) monitor
Screen Shot 2024-10-31 at 21.16.16 PM.png (63.93 KiB) Viewed 1401 times
Screen Shot 2024-10-31 at 21.19.13 PM.png (66.47 KiB) Viewed 1401 times
The attachment Screen Shot 2024-10-31 at 21.19.40 PM.png is no longer available
Screen Shot 2024-10-31 at 21.19.40 PM.png (134.01 KiB) Viewed 1401 times
You want nodect mode for the high rest, not monitor.
