No Views, only in Zoneminder Interface
Posted: Thu Nov 07, 2024 1:23 pm
Hello everyone here,
I just signed up and have been using Zoneminder on an AMD64 PC with Debian 10 - 12 for about 6 years now. I haven't been able to see a live stream in Zoneminder for a few months now, only the "broken image" icon. ZM 1.36.35 is currently running on Bookworm, no major problems when updating Debian, Zoneminder and, for your information, Nextcloud and Openhab.
Only Zoneminder still doesn't show a live stream, sockets are created and /dev/shm is also filled with the correct files, user and group are OK (www-data). The error in the ZM logs is that the socket files are missing (file not found) and no access to /dev/shm/zm.mmap.2 (up to 5) (no such file or directory). As already mentioned, files are present and rights are also correct.
I get a stream in Openhab via the Zoneminder binding and can access images directly with "zmu -m 2 -i -U zr -P xxxx" also for the 3 other monitors. Google searches with the obvious error messages (no socket..., No such file or directory..., Can't connect to capture daemon..., ) gave very similar results, mostly about cgi-bin, but it is Also correct as far as I can see (no error messages in logs from ZM or Apache2 and path is OK) I use FireFox and Chrome as browsers. Nextcloud can be reached from outside, Openhab and Zoneminder can only be reached via VPN from outside the local network.
After weeks of troubleshooting, I don't know what to do anymore, especially since the stream only doesn't work in the ZM web interface. I've tried a few solutions to provoke the errors that are similar to mine (e.g. rights deliberately set incorrectly, paths set incorrectly, etc ) which of course caused the corresponding errors and also disrupted the stream in Openhab and the retrieval of the images. Correcting these errors restored the stream in Openhab and grabbing images worked again as expected, but I can't get a stream in Zoneminder.
Setting up ZM completely again including MariaDB databases hasn't changed anything.
Does anyone here have any advice on where I can check which log files should be activated other than the standard ones? Extra debugging with level 9 didn't bring any further information, and I can't find anything else in the system.log either.
I'm at a loss now, I can't get a picture within ZM.
with many thanks for any help
JP S.
JP S.
