MQTT
atlas
MQTT
Post by atlas »
I have openhab and Eclipse Mosquitto running on the same machine that has zoneminder on it. It looks like the mqtt currently implemented is for subscribing to topics only? I get two error msgs, MQTT publish returns 4 Interrupted system call & MQTT connect returns 15 Block device required
The way I think it should work is to publish messages. So on a Linux machine, apt-get install mosquitto (apt-get install mosquitto-clients as well) and this could send a simple msg to your home automation stuff like turning on a light, or sending a email/sms. This would be far simpler than what ever the current thing is now.
Is there a way to run a command when a camera triggered? If there was a box/empty field for a command when a camera is triggered would be nice, ex,
 mosquitto_pub -h host -t zoneminder –m FrontDoorAlert
Re: MQTT
It should do both. Wwe publish new events. But it's not well tested. No one is using it.
atlas
Re: MQTT
Post by atlas »
iconnor wrote: Mon Nov 25, 2024 3:41 pm It should do both. Wwe publish new events. But it's not well tested. No one is using it.
Hmm, Im still having trouble. 1.37.65
I tried a different approach, I opened up two remote terminals on my zoneminder/mqtt/openhab machine. One terminal I give command
mosquitto_sub -h localhost -t zoneminder
and the other terminal I send it a message
mosquitto_pub -h 192.168.46.3 -t zoneminder -m hi
. This works.
Next I try this from the my desktop computer
sudo -u www-data /usr/bin/mosquitto_pub -h 192.168.46.3 -t zoneminder -m hi
and the message is received on my zoneminder machine as well.
So I move on to the zoneminder web gui - defining monitors -> recording tab -> Event Start Command:
and no luck on that approach as well. I feel like I am getting close.
Re: MQTT
ZM appends event id and monitor id to the command, maybe that is screwing up mostquitto_pub. Maybe try wrapping it in a script which ignores command line parameters?
atlas
Re: MQTT
Post by atlas »
iconnor wrote: Tue Nov 26, 2024 6:41 pm ZM appends event id and monitor id to the command, maybe that is screwing up mostquitto_pub. Maybe try wrapping it in a script which ignores command line parameters?
I think I got it to work (mqtt Publishing) via Recording --> Event Start Command
I put a very basic script in /usr/share/zoneminder/www/ and named it trigger1.sh
the script:
nano /usr/share/zoneminder/www/trigger1.sh
#!/bin/bash
chmod a+x /usr/share/zoneminder/www/trigger1.sh
chown www-data:www-data /usr/share/zoneminder/www/trigger1.sh
Back to zoneminder in the field "Event Start Command" I put :
./trigger1.sh
When I triggered manual alarm I got the "hi" message using terminal with
So this is good enough for me. Thanks for your help, it would be nice to see mqtt fully implemented and buffed out someday as I think its here to stay and going to be used in everything in the future.
