Update LiveCD 1.19.1
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
Serg
Post by Serg »
Many thanks for soft!
Version 1.19.1 works ideally!
But:
I Try to make update up to 1.19.3 and I receive in a window -
<You are running the most recent version of ZoneMinder, v1.19.1. >
<No update is necessary >
That it is necessary to make for update?
zoneminder
Site Admin
Post by zoneminder »
No you don't use the web interface to update ZM. There is an example of how to do an update in this thread. Just do the same but change 1.19.2 to 1.19.3 and when you get to the stage
mysql zm < db/zmalter-1.19.1.sql # Apply database diffs from 1.19.1, you may need to give a username and password here.
make sure you also do
mysql zm < db/zmalter-1.19.2.sql
to apply the DB diffs from 1.19.2 also.
Phil,
Serg
Post by Serg »
Thanks!
I shall try to do update.
One more question: whether it is possible to pass at once from version 1.19.1 to version 1.19.3, without update up to version 1.19.2?
Serg
St. Petersburg, Russia.
zoneminder
Site Admin
Yes, the instructions above assume that you are. You do have to apply any intermediate database changes though which was what I wad demonstrating.
Phil,
Serg
Post by Serg »
Many thanks!
Updating up to version 1.19.3 proceeded only 7 minutes and has come to the end successfully!
P.S.
I can am mistaken, but it seems to me, that buttons NEXT and PREV need to be changed places. Event farther on time - PREV.
zoneminder
Site Admin
Serg wrote:Many thanks!
Good, I'm glad to hear it went well.
P.S.
This issue is more a 'feature' than a 'bug' really and is discussed in this thread.
Phil,
