Page 1 of 1
Frame 1 is old and frames won't display
Posted: Fri Dec 13, 2024 11:32 am
by Pete1
I have a new install of 1.36.35 on Rocky 9.5. I have an issue with the first frame in each event being old.
I installed it a few days ago. I thought it was working but had an issue that a HDD failed, I had left the default location and that filled, preventing database writes as well. To try and ensure that the database had not become an issue, I exported just the configuration from the database, removed the existing database and reinstated, copying my configuration in (I beleive that this returned it to a new install plus my camera settings):
mysql -u root  -e "create database zm;"
mysql -u root  zm < /usr/share/zoneminder/db/zm_create.sql
mysql -u root  zm < zmdb_configonly_12_13_24.sql
I have two issues (they may of course be related).
Firstly, every event (at least all those I have looked at) have an old frame as Frame Id 1 (all timed at 08:57:35, which is five seconds after the zoneminder.service was started). I walked in front of the camera ay about 9:49. This generated 72 events from Event-1 at 9:49:17 through to Event-72 at 9:49:27.
All the frames from the 72 events should have been one contiguous event.
One item from the log:
12/13/24 08:57:35.573714 zmc_m1[530656].WAR-zm_packetqueue.cpp/153 [You have set the max video packets in the queue to 25. The queue is full. Either Analysis is not keeping up or your camera's keyframe interval 24 is larger than this setting.]
Noting that the time is the same as the frame that is being repeated. Maximum Image Buffer Size is set to 25 frames and the camera's "I Frame Gap" (which I think is the the key frame interval) is also 25 (on the camera's web interface it must be greater than or equal to 25). I have Image Buffer Size set to 5.
The server is eight cores and has a load of 1.56 (webmin shows 19%) so it should be able to keep up.
During the time that I walked in front of the camera, for each event there is a line:
12/13/24 09:49:18.670369 zmc_m1[530765].WAR-zm_monitor.cpp/2096 [Driveway: 64644 - event 1, has exceeded desired section length. 1734083358 - 1734080255 = 3103 >= 600]
I presume that is because Frame Id 1 is >600 seconds before all the captured frames.
After Event 13, there is also:
12/13/24 09:49:19.709807 zmc_m1[530656].WAR-zm_packetqueue.cpp/173 [Found locked packet when trying to free up video packets. This means that decoding is not keeping up.]
[This is similar to: viewtopic.php?t=33425 but none of the suggestions in there have helped me to resolve this]. I had it all running up until some months ago on Centos 8, but the OS got corrupted and I've just got around to re-installing it.
Secondly, When I click on the "Frames" option I can see thumbnails but when I then click on a frame to view it, I get a blank screen. I can view the images directly on the server in the appropriate Event folder so they do exist.
Grateful any help to sort these issues.
Re: Frame 1 is old and frames won't display
Posted: Fri Dec 13, 2024 3:22 pm
by iconnor
MaxImageBufferCount should be at least 2*keyframe interval, plus a bit more. Don't worry too much about setting it too high it will only get used if needed.
Posted: Sat Dec 14, 2024 2:05 pm
by Pete1
Excellent - issue 1 seems to be resovled thanks. All three of my cameras will now record on motion detection and the first frame is not old, with several captures off each camera triggered by movement.
Issue 2 (not loading frames) is present on two of the three cameras I have configured. On the third when I click on a frame ID the image is shown as expected. So that wasn't seemingly related to the first issue.
However now (as I write this), the third camera is also now not showing frames - what seemed to trigger this was clicking on the Auto size button top right and then the Next button at the bottom. Then nothing displayed (blank browser screen) and even going back to the console and back to viewing frames didn't work. Previously I had viewed a number of frames off this camera without issue.
What I have identified is that switching from low bandwidth to high bandwidth. As far as I can see there is nothing under the configuration of each bandwidth that should have this effect. For now I will leave it in High bandwidth mode, but if there is anything I need to debug to raise an issue then happy to try things out.
Posted: Sat Dec 14, 2024 6:55 pm
by iconnor
I have afix that will be in 1.36.36.
Edit /usr/share/zoneminder/www/include/Event.php line 440 from
if ( !ZM_WEB_SCALE_THUMBS || ($scale >= SCALE_BASE) || !function_exists('imagecreatefromjpeg') ) {
to
if ( !ZM_WEB_SCALE_THUMBS || !$scale || ($scale >= SCALE_BASE) || !function_exists('imagecreatefromjpeg') ) {
