raspi + uv4l + rpi cam + zoneminder not working
Posted: Thu Dec 19, 2024 10:35 am
All, I think I have a very basic and simple setup but fail to get it working. See what I have:
Raspi with bullseye 32 Bit running uv4l service, stream work great with URL like http://ip:8080/stream (mjpeg)
zoneminder 1.36.33 running on another pi.
I was following diverse tutorials to add the cam as following:
general: remote + modect
source: http + simple + hostname is the IP + port is 8080 path is "stream". Resolution exactly as set up in uv4l server
error log shows:
Monitor shm is not connected
Can't open memory map file /dev/shm/zm.mmap.1: No such file or directory --> checked, it is there and has proper attributes
Running out of ideas here as all the tutorials simply tell the settings as I have them. Any idea from you folks here?
error log shows:
