Page 1 of 1
how to jump on 1.37 on raspberry 5
Posted: Tue Dec 24, 2024 10:59 am
by mirco
Hello! As a newcomer to the ZoneMinder community, I'm currently experimenting with version 1.36.33 on a Raspberry Pi 5 (bookworm) with a single monitor, and it's working well for me. I'm interested in the MQTT features and am considering switching to the development version 1.37. My question is: Is there a smooth way to upgrade from the stable version to the development version?
Re: how to jump on 1.37 on raspberry 5
Posted: Tue Dec 24, 2024 6:36 pm
by iconnor
Yes, just add the repo for master to apt and apt install zoneminder.
If on pi os you need to setup the zmrepo. https://zmrepo.zoneminder.com
Posted: Thu Dec 26, 2024 3:10 pm
by mirco
thank you!! while I was struggling with the instructions on zmrepo I found this https://wiki.zoneminder.com/Debian_12_B ... der_1.37.x very helpful. Running on 1.37 now testing mqtt integration.
Posted: Fri Apr 04, 2025 8:36 am
by bluecoffee
What kind of performance does the Pi 5 give, in terms of number of cameras, resolution, fps? I'm thinking of using one for Zoneminder. I can only find benchmark info for the Pi 4.
