Start & Stop surveillance via external keypad (PIN)
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
blixa
Post by blixa »
hi,
what about support for external keypads connected on serial/parport/gameport?
it would be great if i could start and stop the surveillance mode with a special PIN.
thanks, holger
ajpalm
Post by ajpalm »
This isn't really a zoneminder thing, as I wouldn't want my system to be off, just incase something happened and I forgot to turn it on!
For this to work even if it was built into zoneminder, it would need a input somehow to know when the correct code has been entered.
Rather than building it into zonemind, why don't you just have a script on box that turns the service off and on via a script.
Andrew
djsb
Post by djsb »
Maybe you want to try this out:
http://www.silicontao.com/gallery_image ... /info.html
It's an interface with the serial port. It can list to all that comes into it. You can plug anything on the serial port and then take your actions based on what comes.
