The dreaded orange
rbrowning3
The dreaded orange
Post by rbrowning3 »
Hi
I've got ZM 1.19.2 running; things seem to be configured OK. In fact, my original ZM installation worked, but something I've done has borked it.
In the main console screen I get the Source of /dev/video0(1) in orange, not a helpful green. The camera's watch screen works ok (I see the correct image.)
zmdc.log gives me:
Starting pending process, zma -m 1
'zma -m 1' starting at 04/05/08 11:53:04, pid = 2974
'zma -m 1' started at 04/05/08 11:53:04
'zma -m 1' crashed at 04/05/08 11:53:04, exit status 11
Can anyone help? Thanks.
R
victor_diago
Post by victor_diago »
hi, i have seen a lot of this..
in my case, it was because the databases where corrupted (or the filesystem)
try do myisamchk -r in ALL your MYI files under zm database's directory..
OH important, STOP ZONEMINDER AND MYSQL BEFORE IT...
ALSO, check your shared memory size, it should be a little greater than the default. learn how to up it at the faq.
victor diago
