Seek Event video, play, queue
Posted: Fri Jan 03, 2025 10:25 pm
I had managed to build and learn, config this app in my test server.
Installed from
deb https://zmrepo.zoneminder.com/debian/release-1.36 buster/ -- I know I have an old server zm v1.36.34
Everything seems working after couple of weeks of tweaking here and there following the how-to;s.
I managed also zxNinja to configure. Something common does not work on both systems - zone-minder and zmNinja.
When playing an event without touching the video timeline - slider, works (plays from beginning to end) on both systems (mobile "Event List > Footage" and zm website) but if I choose to seek - move the cursor to another part of the video the play stops complete, freeze the play (not before showing a image or somethimes goes to the end completly) I had managed couple of time to click close to another point on the slider and the video was playing but very rare occasions.
I have this log on zoneminder website:
on apache error side
There are all kinds of references tried to follow but I am lost now. Does not bother me, still its an amazing work and application.
I have followed the easy way to install on bare metal.
Installed from
1/3/25, 5:10:47 PM EST web_js 28932 ERR getCmdResponse stream error: socket_sendto( /run/zm/zms-774282s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event&eid=3212&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=3&filter%5BQuery%5D%5Bsort_asc%5D=0&filter%5BQuery%5D%5Bsort_field%5D=StartDateTime&f -
1/3/25, 5:10:47 PM EST web_php 28932 ERR socket_sendto( /run/zm/zms-774282s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 1884
1/3/25, 5:10:44 PM EST web_js 28932 ERR getCmdResponse stream error: socket_sendto( /run/zm/zms-774282s.sock ) failed: Connection refused - checkStreamForErrors() ?view=event&eid=3212&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=3&filter%5BQuery%5D%5Bsort_asc%5D=0&filter%5BQuery%5D%5Bsort_field%5D=StartDateTime&f -
1/3/25, 5:10:44 PM EST web_php 28932 ERR socket_sendto( /run/zm/zms-774282s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php
AH01220: Timeout waiting for output from CGI script /usr/lib/zoneminder/cgi-bin/nph-zms, referer: https://obelix.xxx.local/zm/?view=event&eid=3212&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=3&filter%5BQuery%5D%5Bsort_asc%5D=0&filter%5BQuery%5D%5Bsort_field%5D=StartDateTime&filter%5BQuery%5D%5Blimit%5D=0&sort_field=StartDateTime&sort_asc=0&page=1
[Fri Jan 03 17:10:40.410238 2025] [cgi:warn] [pid 30974] [client xx.xx.xx.xx:63431] AH01220: Timeout waiting for output from CGI script /usr/lib/zoneminder/cgi-bin/nph-zms, referer: https://obelix.xxx.local/zm/?view=event&eid=3212&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=3&filter%5BQuery%5D%5Bsort_asc%5D=0&filter%5BQuery%5D%5Bsort_field%5D=StartDateTime&filter%5BQuery%5D%5Blimit%5D=0&sort_field=StartDateTime&sort_asc=0&page=1
