Similar error messages around midnight, daily. V1.36.35
jrf
Post by jrf »
Hi alll,
does by any chance s/o knows why I do have similar error messages every day? Date/Time shown format is German/MEZ:
Date/Time,Component,Server,PID,Level,Message,File,Line
"08.01.25, 01:00:02 MEZ",zmdc,,1069,ERR,"'zmupdate.pl -c' exited abnormally, exit status 9",zmdc.pl,'-
"08.01.25, 00:00:02 MEZ",zmc_m2,,117441,ERR,"Failed to capture image from monitor 2 Zugang (1/1)",zmc.cpp,305
"08.01.25, 00:00:02 MEZ",zmc_m2,,117441,ERR,"Unable to get response, disconnecting",zm_remote_camera_http.cpp,1087
"08.01.25, 00:00:02 MEZ",zmc_m2,,117441,ERR,"Unable to read subheader",zm_remote_camera_http.cpp,937
"08.01.25, 00:00:02 MEZ",zmc_m2,,117441,ERR,"Select error: Interrupted system call",zm_remote_camera_http.cpp,241
"08.01.25, 00:00:02 MEZ",zmc_m1,,123909,ERR,"Failed to capture image from monitor 1 Eingang (1/1)",zmc.cpp,305
"08.01.25, 00:00:02 MEZ",zmc_m1,,123909,ERR,"Unable to get response, disconnecting",zm_remote_camera_http.cpp,1087
"08.01.25, 00:00:02 MEZ",zmc_m1,,123909,ERR,"Unable to read subheader",zm_remote_camera_http.cpp,937
"08.01.25, 00:00:02 MEZ",zmc_m1,,123909,ERR,"Select error: Interrupted system call",zm_remote_camera_http.cpp,241
"07.01.25, 00:00:01 MEZ",zmc_m1,,86864,ERR,"Select error: Interrupted system call",zm_remote_camera_http.cpp,241
"07.01.25, 00:00:01 MEZ",zmwatch,,1419,ERR,"Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach.  zmc might not be running.",zmwatch.pl,'-
"07.01.25, 00:00:01 MEZ",zmc_m2,,117441,ERR,"Failed to capture image from monitor 2 Zugang (1/1)",zmc.cpp,305
"07.01.25, 00:00:01 MEZ",zmc_m1,,86864,ERR,"Failed to capture image from monitor 1 Eingang (1/1)",zmc.cpp,305
"07.01.25, 00:00:01 MEZ",zmc_m2,,117441,ERR,"Unable to get response, disconnecting",zm_remote_camera_http.cpp,1087
"07.01.25, 00:00:01 MEZ",zmc_m2,,117441,ERR,"Unable to read subheader",zm_remote_camera_http.cpp,937
"07.01.25, 00:00:01 MEZ",zmc_m1,,86864,ERR,"Unable to get response, disconnecting",zm_remote_camera_http.cpp,1087
"07.01.25, 00:00:01 MEZ",zmc_m1,,86864,ERR,"Unable to read subheader",zm_remote_camera_http.cpp,937
"07.01.25, 00:00:01 MEZ",zmc_m2,,117441,ERR,"Select error: Interrupted system call",zm_remote_camera_http.cpp,241
I do have four WiFi cameras connected, but only m1 and m2 seem to have errors. I know them, I can ignore them but maybe s/o knows a solution?
Best regards from South Germany,
JRF
Andyrh
Re: Similar error messages around midnight, daily. V1.36.35
Post by Andyrh »
That looks similar to when my cameras restart once a week. Are your cameras restarting?
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
There is a log rotate that happens at midnight, wouldn't expect it to cause those errors though
jrf
Post by jrf »
Andyrh wrote: Wed Jan 08, 2025 7:27 pm That looks similar to when my cameras restart once a week. Are your cameras restarting?
Not that I would be aware of. The cameras have no Internet access (blocked in the router because they chat to much with obscure IP addresses), so I cannot imagine that they have a synchronized time and would restart midnight sharp.
JRF
Andyrh
Post by Andyrh »
Then it is down to basic troubleshooting.
I would start with pinging a working and troublesome camera just before midnight until the problem occurs to see if the camera remains on-line. This will show if it is ZM or not.
If the 2 test cameras use the same AP, this will show if it is the AP or the camera.
This simple test may isolate the problem.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
