increases CPU consumption
pepex7
Post by pepex7 »
Hi, I have ZM 1.37.65 in Ubuntu server 24.04 running very well for weeks, suddenly server 2 (multiserver) increases CPU consumption (this causes the images from the cameras on that server to become pixelated) and a few hours pass and then it is fine again.
attached images.
When I restart the zoneminder service (systemctl restart zoneminder) everything is fine again and it remains for days.
Captura de Pantalla 2025-01-20 a la(s) 13.20.20.png (294.31 KiB) Viewed 2428 times
Captura de Pantalla 2025-01-20 a la(s) 13.13.07.png (233.6 KiB) Viewed 2428 times
Captura de Pantalla 2025-01-20 a la(s) 13.02.38.png (283.73 KiB) Viewed 2428 times
Joe_77
Re: increases CPU consumption
Post by Joe_77 »
what kind of hardware do you use? I think my CPU load is also higher then with 1.36. I use the Zoneminder with Ubuntu 24.04 on a VM. The Hardware is Intel i9 12900K an the VM uses 8 Cores. The CPU load is about 30%. With Ubuntu 22.04. and 1.36 it was 10% i think.
Kind regards
Jochen
