User rights
voz
User rights
Post by voz »
If I have 10 cameras. Is it possible to add only a few cameras for a user to view?
And is it possible to combine several cameras into a group? Should access be provided in groups?
As I understand it, user rights to view specific cameras are saved in the database? Or is it all saved to a file?
burger
Re: User rights
Post by burger »
voz wrote: Mon Jan 27, 2025 3:31 pm If I have 10 cameras. Is it possible to add only a few cameras for a user to view?
User permissions are handled in the user management screen. Under Options - Users - Restricted Monitors. https://zoneminder.readthedocs.io/en/st ... users.html
Yes, Groups are implemented in ZM. First they are created, and cameras added to them. I think it's possible to set a default view in the Users tab for a group. Though I would need to double check. If monitors are restricted, I don't think they will show up in groups, or at least the user will not be able to view them. http://ipaddress/zm/?view=groups
Everything is saved in the Database. https://wiki.zoneminder.com/MySQL
fastest way to test streams:
voz
Re: User rights
Post by voz »
Site unavailable
