add event using api
farzam
add event using api
Post by farzam »
With this code, I can create an event and save its frames, but when I go to the event, it doesn't show any images. However, the snapshot is displayed correctly. What should I do to ensure the event is registered properly and I can see the frames in the event?
from ultralytics import YOLO
import cv2
import requests
import time
import json
import os
from datetime import datetime, timedelta
# ZoneMinder API details
ZM_URL = "http://172.16.32.139/zm/"
ZM_MONITOR_ID = 1  # Monitor ID
YOLO_MODEL_PATH = "yolo11n.pt"  # Path to YOLO model
model = YOLO(YOLO_MODEL_PATH)
def get_last_event_id():
    """Get the last event ID by checking all events."""
    events_url = f"{ZM_URL}api/events.json"
    try:
        response = requests.get(events_url)
        if response.status_code != 200:
            print(f"Error: Status code {response.status_code}")
            return None
        events_data = response.json()
        if "events" not in events_data:
            print("Invalid JSON structure. 'events' key not found.")
            return None
        events = events_data["events"]
        if not events:
            print("No events found.")
            return None
        try:
            max_id_event = max(events, key=lambda x: x["Event"]["Id"])
            last_event_id = max_id_event["Event"]["Id"]
            print(f"Last event ID: {last_event_id}")
            return last_event_id
        except KeyError as e:
            print(f"Invalid event structure. Key {e} not found.")
            return None
    except requests.exceptions.RequestException as e:
        print(f"Request error: {e}")
        return None
def create_zm_event():
    """Create a new event in ZoneMinder and return its ID."""
    try:
        start_time = datetime.now()
        end_time = start_time + timedelta(seconds=3)
        start_time_str = start_time.strftime("%Y-%m-%d %H:%M:%S")
        end_time_str = end_time.strftime("%Y-%m-%d %H:%M:%S")
        event_url = f"{ZM_URL}api/events.json"
        event_data = {
            "MonitorId": ZM_MONITOR_ID,
            "Cause": "Human detected",
            "StateId": 1,
            "StartDateTime": start_time_str,
            "EndDateTime": end_time_str,
            "Frames": 3,
            "Width": 640,
            "Height": 480
        response = requests.post(event_url, data=event_data)
        print(f"Status Code: {response.status_code}")
        print(f"Response Text: {response.text}")
        if response.status_code in (200, 201):
            try:
                response_json = response.json()
                if "event" in response_json and "Id" in response_json["event"]:
                    event_id = response_json["event"]["Id"]
                    print(f"Event created! ID: {event_id}")
                    return event_id
                else:
                    print("Invalid JSON structure. Missing 'event' or 'Id'.")
                    return None
            except json.JSONDecodeError:
                print("Invalid JSON response.")
                return None
        else:
            print(f"Error: API returned status code {response.status_code}")
            return None
        print(f"Request failed: {e}")
        return None
def trigger_zm_event(event_id, frame):
    """Register the event in ZoneMinder."""
    event_folder_path = f"/var/cache/zoneminder/events/{ZM_MONITOR_ID}/{time.strftime('%Y-%m-%d')}/{event_id}"
    os.makedirs(event_folder_path, exist_ok=True)
    create_zm_event()
    filename1 = f"{event_folder_path}/00001-capture.jpg"
    filename2 = f"{event_folder_path}/00002-capture.jpg"
    filename3 = f"{event_folder_path}/00003-capture.jpg"
    filename4 = f"{event_folder_path}/snapshot.jpg"
    filename5 = f"{event_folder_path}/alarm.jpg"
    cv2.imwrite(filename1, frame)
    cv2.imwrite(filename2, frame)
    cv2.imwrite(filename3, frame)
    cv2.imwrite(filename4, frame)
    cv2.imwrite(filename5, frame)
    print(f"Frame saved to {filename1}")
def detect_human(frame):
    """Detect humans in the frame using YOLOv8."""
    results = model(frame)
    for result in results:
        for det in result.boxes:
            if model.names[int(det.cls)] == "person":  # Check for human class
                return True
    return False
def main():
    cap = cv2.VideoCapture(f"{ZM_URL}cgi-bin/nph-zms?mode=jpeg&monitor={ZM_MONITOR_ID}&scale=100&maxfps=10")
    last_event_id = 93
    while True:
        ret, frame = cap.read()
        if not ret:
            print("Failed to capture frame from ZoneMinder stream.")
            break
        if detect_human(frame):
            last_event_id += 1
            print("Human detected! Registering event in ZoneMinder...")
            trigger_zm_event(last_event_id, frame)
            time.sleep(10)  # Cooldown to avoid multiple events
    cap.release()
if __name__ == "__main__":
    main()
