busymind
Posts: 39 Joined: Fri Jan 03, 2025 9:55 pm
Post
by busymind » Wed Feb 26, 2025 8:30 pm
Zoneminder crash after today's upgrade. Logs are filling rapidly. Debian12. I forget to take a system snapshot
[/code]
Get:1 https://zmrepo.zoneminder.com/debian/master bookworm/ zoneminder 1.37.66~20250226.7-bookworm [8,190 kB]
Get:2 https://zmrepo.zoneminder.com/debian/master bookworm/ zoneminder-doc 1.37.66~20250226.7-bookworm [8,482 kB]
Fetched 16.7 MB in 8s (1,995 kB/s)
Reading changelogs... Done
(Reading database ... 60045 files and directories currently installed.)
Preparing to unpack .../zoneminder_1.37.66~20250226.7-bookworm_amd64.deb ...
Unpacking zoneminder (1.37.66~20250226.7-bookworm) over (1.37.65~20250225.168-bookworm) ...
Preparing to unpack .../zoneminder-doc_1.37.66~20250226.7-bookworm_all.deb ...
Unpacking zoneminder-doc (1.37.66~20250226.7-bookworm) over (1.37.65~20250225.168-bookworm) ...
Setting up zoneminder-doc (1.37.66~20250226.7-bookworm) ...
Setting up zoneminder (1.37.66~20250226.7-bookworm) ...
detected systemd
Warning: The unit file, source configuration file or drop-ins of zoneminder.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Detected db service is mariadb.service
Checking for db
Db exists.
Updating permissions for user zmuser@localhost
Initiating database upgrade to version 1.37.66 from version 1.37.65
Upgrading database to version 1.37.66
Upgrading DB to 1.37.66 from 1.37.65
Database successfully upgraded to version 1.37.66.
Database upgrade to version 1.37.66 successful.
Freshening configuration in database
Migratings passwords, if any...
Loading config from DB 242 entries
Saving config to DB 242 entries
Done Updating
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for man-db (2.11.2-2) ...
2025-02-26T15:34:28.024388-05:00 zoneminder kernel: [18840.017931] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:28.027962-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:28 2826 [Warning] Aborted connection 2826 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:29.296366-05:00 zoneminder kernel: [18841.290606] zmc[7997]: segfault at 0 ip 00007fa752667c77 sp 00007ffcae251190 error 4 in libc.so.6[7fa752645000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T15:34:29.296409-05:00 zoneminder kernel: [18841.290634] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:29.299928-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:29 2829 [Warning] Aborted connection 2829 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:32.756375-05:00 zoneminder kernel: [18844.749528] zmc[8001]: segfault at 0 ip 00007f36ac867c77 sp 00007ffc0745ee40 error 4 in libc.so.6[7f36ac845000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T15:34:32.756408-05:00 zoneminder kernel: [18844.749555] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:32.758899-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:32 2834 [Warning] Aborted connection 2834 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:33.108318-05:00 zoneminder kernel: [18845.102162] zmc[8005]: segfault at 0 ip 00007ff9a8e67c77 sp 00007ffd458ea960 error 4 in libc.so.6[7ff9a8e45000+155000] likely on CPU 3 (core 1, socket 1)
2025-02-26T15:34:33.108351-05:00 zoneminder kernel: [18845.102192] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:33.108355-05:00 zoneminder kernel: [18845.102755] zmc[8006]: segfault at 0 ip 00007fa06c867c77 sp 00007ffee8b79da0 error 4 in libc.so.6[7fa06c845000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T15:34:33.108357-05:00 zoneminder kernel: [18845.102780] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:33.110717-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:33 2839 [Warning] Aborted connection 2839 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:33.112204-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:33 2840 [Warning] Aborted connection 2840 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:34.392396-05:00 zoneminder kernel: [18846.386339] zmc[8009]: segfault at 0 ip 00007fda00267c77 sp 00007fffcd610730 error 4 in libc.so.6[7fda00245000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T15:34:34.392445-05:00 zoneminder kernel: [18846.386368] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:34.395528-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:34 2843 [Warning] Aborted connection 2843 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:38.676351-05:00 zoneminder kernel: [18850.671828] zmc[8011]: segfault at 0 ip 00007f8f75467c77 sp 00007ffff6eb32e0 error 4 in libc.so.6[7f8f75445000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T15:34:38.676386-05:00 zoneminder kernel: [18850.671856] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:38.681697-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:38 2846 [Warning] Aborted connection 2846 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:39.960422-05:00 zoneminder kernel: [18851.954464] zmc[8013]: segfault at 0 ip 00007f99e8067c77 sp 00007fffe0f6cfb0 error 4 in libc.so.6[7f99e8045000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T15:34:39.960458-05:00 zoneminder kernel: [18851.954492] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:39.963945-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:39 2849 [Warning] Aborted connection 2849 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
some other logs
2025-02-26T15:39:01.908000-05:00 zoneminder CRON[8489]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
2025-02-26T15:39:30.378553-05:00 zoneminder systemd[1]: Starting phpsessionclean.service - Clean php session files...
2025-02-26T15:39:30.711234-05:00 zoneminder systemd[1]: phpsessionclean.service: Deactivated successfully.
2025-02-26T15:39:30.711685-05:00 zoneminder systemd[1]: Finished phpsessionclean.service - Clean php session files.
2025-02-26T15:42:54.525276-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Got signal 11 (Segmentation fault), crashing]
2025-02-26T15:42:54.529370-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Signal address is (nil), from 0x7f67c8667c77]
2025-02-26T15:42:54.530189-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Got signal 11 (Segmentation fault), crashing]
2025-02-26T15:42:54.530565-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Signal address is (nil), from 0x7fd120667c77]
2025-02-26T15:42:54.530818-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xc9dfe) [0x564ee3b3bdfe]]
2025-02-26T15:42:54.531070-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xc9dfe) [0x558b1f5cbdfe]]
2025-02-26T15:42:54.531303-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7fd12065b050]]
2025-02-26T15:42:54.531558-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(+0x48c77) [0x7fd120667c77]]
2025-02-26T15:42:54.531809-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x5f703) [0x564ee3ad1703]]
2025-02-26T15:42:54.532138-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7f67c865b050]]
2025-02-26T15:42:54.532497-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x6b256) [0x564ee3add256]]
2025-02-26T15:42:54.532813-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(+0x48c77) [0x7f67c8667c77]]
2025-02-26T15:42:54.533105-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xcc6bc) [0x564ee3b3e6bc]]
2025-02-26T15:42:54.533378-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0x143b) [0x564ee3aa0a1b]]
2025-02-26T15:42:54.533678-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x5f703) [0x558b1f561703]]
2025-02-26T15:42:54.533976-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7fd12064624a]]
2025-02-26T15:42:54.534255-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7fd120646305]]
2025-02-26T15:42:54.534593-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x6b256) [0x558b1f56d256]]
2025-02-26T15:42:54.534872-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 9: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x31961) [0x564ee3aa3961]]
2025-02-26T15:42:54.534998-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xcc6bc) [0x558b1f5ce6bc]]
2025-02-26T15:42:54.535157-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
2025-02-26T15:42:54.535321-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [and execute the following command for more information:]
2025-02-26T15:42:54.535427-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0x143b) [0x558b1f530a1b]]
2025-02-26T15:42:54.535606-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [addr2line -Cfip -e /usr/lib/zoneminder/cgi-bin/nph-zms 0xc9dfe 0x5f703 0x6b256 0xcc6bc 0x31961]
2025-02-26T15:42:54.535720-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7f67c864624a]]
2025-02-26T15:42:54.535891-05:00 zoneminder zms_m1[8564]: FAT [zms_m1] [Got signal 11 (Segmentation fault), crashing]
2025-02-26T15:42:54.536007-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f67c8646305]]
2025-02-26T15:42:54.536362-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 9: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x31961) [0x558b1f533961]]
2025-02-26T15:42:54.536496-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
2025-02-26T15:42:54.536697-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [and execute the following command for more information:]
2025-02-26T15:42:54.536839-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [addr2line -Cfip -e /usr/lib/zoneminder/cgi-bin/nph-zms 0xc9dfe 0x5f703 0x6b256 0xcc6bc 0x31961]
2025-02-26T15:42:54.537006-05:00 zoneminder zms_m2[8563]: FAT [zms_m2] [Got signal 11 (Segmentation fault), crashing]
2025-02-26 15_28_39-Clipboard.png (74.18 KiB) Viewed 22027 times
Posts: 3390 Joined: Fri Oct 29, 2010 1:43 am
Post
by iconnor » Wed Feb 26, 2025 9:14 pm
Have you run zmupdate.pl -f?
busymind
Post
by busymind » Wed Feb 26, 2025 9:18 pm
I run it now. Seems continue crashing
2025-02-26 16_18_15-Clipboard.png (34.9 KiB) Viewed 21973 times
2025-02-26 16_17_34-Clipboard.png (66.31 KiB) Viewed 21973 times
busymind
Post
by busymind » Wed Feb 26, 2025 9:24 pm
The system had run rock solid. The only thing I made from yesterdays before update was to install postfix to send messages.
installed:
apt install mailutils net-tools
install postfix
apt-get install ca-certificates
and some dependencies with
That's all. Thanks
Post
by iconnor » Wed Feb 26, 2025 9:28 pm
zmupdate.pl -f
Please note the -f.
busymind
Post
by busymind » Wed Feb 26, 2025 9:30 pm
Sorry, yes with -f
root@zoneminder:~# zmupdate.pl -f
root@zoneminder:~# tail -f /var/log/syslog
2025-02-26T16:28:53.659411-05:00 zoneminder mariadbd[672]: 2025-02-26 16:28:53 468 [Warning] Aborted connection 468 to db: 'zm' user: 'zmuse r' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:28:53.916996-05:00 zoneminder kernel: [ 750.091699] zmc[1593]: segfault at 0 ip 00007fa299467c77 sp 00007ffd97e4c150 error 4 in libc.so.6[7fa299445000+155000] likely on CPU 3 (core 1, socket 1)
2025-02-26T16:28:53.917030-05:00 zoneminder kernel: [ 750.091751] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 0 0 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:28:53.919681-05:00 zoneminder mariadbd[672]: 2025-02-26 16:28:53 472 [Warning] Aborted connection 472 to db: 'zm' user: 'zmuse r' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:28:54.184889-05:00 zoneminder kernel: [ 750.358066] zmc[1598]: segfault at 0 ip 00007f8dfa267c77 sp 00007ffcc6349570 error 4 in libc.so.6[7f8dfa245000+155000] likely on CPU 2 (core 0, socket 1)
2025-02-26T16:28:54.184920-05:00 zoneminder kernel: [ 750.358094] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 0 0 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:28:54.189628-05:00 zoneminder mariadbd[672]: 2025-02-26 16:28:54 483 [Warning] Aborted connection 483 to db: 'zm' user: 'zmuse r' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:28:54.196863-05:00 zoneminder kernel: [ 750.370751] zmc[1600]: segfault at 0 ip 00007f65a6667c77 sp 00007ffd64adfa50 error 4 in libc.so.6[7f65a6645000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T16:28:54.196877-05:00 zoneminder kernel: [ 750.370767] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 0 0 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:28:54.198148-05:00 zoneminder mariadbd[672]: 2025-02-26 16:28:54 484 [Warning] Aborted connection 484 to db: 'zm' user: 'zmuse r' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:28:55.254070-05:00 zoneminder systemd[1]: Started zoneminder.service - ZoneMinder CCTV recording and surveillance system.
2025-02-26T16:28:55.255472-05:00 zoneminder mariadbd[672]: 2025-02-26 16:28:55 459 [Warning] Aborted connection 459 to db: 'zm' user: 'zmuse r' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:28:56.434429-05:00 zoneminder zmtelemetry[1624]: WAR [Telemetry server returned HTTP POST error code: 301]
2025-02-26T16:28:59.772887-05:00 zoneminder kernel: [ 755.947865] zmc[1648]: segfault at 0 ip 00007f820be67c77 sp 00007ffc43e17670 error 4 in libc.so.6[7f820be45000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T16:28:59.772922-05:00 zoneminder kernel: [ 755.947892] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:28:59.772926-05:00 zoneminder kernel: [ 755.949395] zmc[1649]: segfault at 0 ip 00007efd19267c77 sp 00007ffe5b6f8300 error 4 in libc.so.6[7efd19245000+155000] likely on CPU 2 (core 0, socket 1)
2025-02-26T16:28:59.772929-05:00 zoneminder kernel: [ 755.949419] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:28:59.777925-05:00 zoneminder mariadbd[672]: 2025-02-26 16:28:59 515 [Warning] Aborted connection 515 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:28:59.779540-05:00 zoneminder mariadbd[672]: 2025-02-26 16:28:59 514 [Warning] Aborted connection 514 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:29:10.064924-05:00 zoneminder kernel: [ 766.239030] zmc[1652]: segfault at 0 ip 00007f05d3467c77 sp 00007ffd40869980 error 4 in libc.so.6[7f05d3445000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T16:29:10.064964-05:00 zoneminder kernel: [ 766.239059] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:29:10.064969-05:00 zoneminder kernel: [ 766.239745] zmc[1653]: segfault at 0 ip 00007f943aa67c77 sp 00007ffd9ffe6e10 error 4 in libc.so.6[7f943aa45000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T16:29:10.064971-05:00 zoneminder kernel: [ 766.239769] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:29:10.068471-05:00 zoneminder mariadbd[672]: 2025-02-26 16:29:10 520 [Warning] Aborted connection 520 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:29:10.070670-05:00 zoneminder mariadbd[672]: 2025-02-26 16:29:10 521 [Warning] Aborted connection 521 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:29:25.228979-05:00 zoneminder kernel: [ 781.403178] zmc[1658]: segfault at 0 ip 00007f3191667c77 sp 00007ffc68961620 error 4 in libc.so.6[7f3191645000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T16:29:25.229017-05:00 zoneminder kernel: [ 781.403207] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:29:25.232519-05:00 zoneminder mariadbd[672]: 2025-02-26 16:29:25 526 [Warning] Aborted connection 526 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:29:25.516923-05:00 zoneminder kernel: [ 781.691351] zmc[1662]: segfault at 0 ip 00007f4cfb667c77 sp 00007ffe342a6190 error 4 in libc.so.6[7f4cfb645000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T16:29:25.516955-05:00 zoneminder kernel: [ 781.691378] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:29:25.519896-05:00 zoneminder mariadbd[672]: 2025-02-26 16:29:25 531 [Warning] Aborted connection 531 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:29:25.540889-05:00 zoneminder kernel: [ 781.715378] zmc[1663]: segfault at 0 ip 00007f0c0f667c77 sp 00007ffc48a80060 error 4 in libc.so.6[7f0c0f645000+155000] likely on CPU 2 (core 0, socket 1)
2025-02-26T16:29:25.540909-05:00 zoneminder kernel: [ 781.715402] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:29:25.544051-05:00 zoneminder mariadbd[672]: 2025-02-26 16:29:25 532 [Warning] Aborted connection 532 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T16:29:25.788905-05:00 zoneminder kernel: [ 781.964255] zmc[1667]: segfault at 0 ip 00007ff6a4467c77 sp 00007fff68ea8560 error 4 in libc.so.6[7ff6a4445000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T16:29:25.788935-05:00 zoneminder kernel: [ 781.964284] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T16:29:25.792945-05:00 zoneminder mariadbd[672]: 2025-02-26 16:29:25 535 [Warning] Aborted connection 535 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26 16_32_42-Clipboard.png (84.74 KiB) Viewed 21956 times
busymind
Post
by busymind » Wed Feb 26, 2025 10:02 pm
just to add this info, cameras themselves are working fine; I have another old server on 1.36.34 which I want to decommission it.
2025-02-26 17_01_40-Clipboard.png (72.89 KiB) Viewed 21918 times
busymind
Post
by busymind » Wed Feb 26, 2025 11:26 pm
I had performed a downgrade, back 1.37.65; my first downgrade.
Now is back to working condition.
gyzod
Posts: 11 Joined: Wed Jun 15, 2022 8:52 pm
Post
by gyzod » Thu Feb 27, 2025 12:10 am
Exact same problem here. Built 2 hours ago.
Post
by iconnor » Thu Feb 27, 2025 1:45 am
Just pushed a fix
klui
Posts: 14 Joined: Wed Oct 26, 2016 11:16 pm
Post
by klui » Thu Feb 27, 2025 2:23 am
I just updated on Ubuntu 20.04 and ran into something similar. I saw something new was pushed and performed another dist-upgrade which installed 1.37.66~20250227.10-focal, but no difference.
The problem is directory modes got messed up.
Feb 26 18:16:36 ubuntuz zmpkg.pl[2426]: WARNING: ZoneMinder configuration file found but is not readable. Check file permissions on /etc/zm/zm.conf
/etc/zm and conf.d and file modes were all 640. chmod directories 755 and files 644 then restarting the service fixed it.
busymind
Post
by busymind » Thu Feb 27, 2025 2:27 am
Completely dead.
My station may not be the best because I downgraded earlier. But does not start
run this also zmupdate.pl -f after seeing not starting up but without success.
root@zoneminder:~# journalctl -xeu zoneminder.service
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: WARNING: ZoneMinder configuration file found but is not readable. Check file permissions on /etc/zm/zm.conf
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Use of uninitialized value $ZoneMinder::Config::Config{"ZM_DB_HOST"} in pattern match (m//) at /usr/share/perl5/ZoneMinder/Database.pm line 86.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Use of uninitialized value $ZoneMinder::Config::Config{"ZM_DB_HOST"} in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Database.pm line 96.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Database.pm line 115.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Use of uninitialized value $ZoneMinder::Config::Config{"ZM_DB_TYPE"} in string eq at /usr/share/perl5/ZoneMinder/Database.pm line 115.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Use of uninitialized value $DBI::errstr in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Database.pm line 119.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Logger.pm line 197.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Logger.pm line 245.
Feb 26 21:23:29 zoneminder zmdc[1272]: ERR [Error reconnecting to db: errstr: error val:Can't connect to data source 'DBI::database=;host=' because I can't work out what driver to use (it doesn't seem to contain a 'dbi:driver:' prefix >
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Unable to connect to DB. ZM Cannot continue.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 150.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: Compilation failed in require at /usr/bin/zmdc.pl line 67.
Feb 26 21:23:29 zoneminder zmpkg.pl[1272]: BEGIN failed--compilation aborted at /usr/bin/zmdc.pl line 67.
Feb 26 21:23:29 zoneminder sudo[1271]: pam_unix(sudo:session): session closed for user www-data
Feb 26 21:23:29 zoneminder zmpkg[1263]: ERR [Unable to run "sudo -u www-data /usr/bin/zmdc.pl check", output is "", status is 25]
Feb 26 21:23:29 zoneminder systemd[1]: zoneminder.service: Control process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ An ExecStart= process belonging to unit zoneminder.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Feb 26 21:23:29 zoneminder systemd[1]: zoneminder.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit zoneminder.service has entered the 'failed' state with result 'exit-code'.
Feb 26 21:23:29 zoneminder systemd[1]: Failed to start zoneminder.service - ZoneMinder CCTV recording and surveillance system.
░░ Subject: A start job for unit zoneminder.service has failed
░░ A start job for unit zoneminder.service has finished with a failure.
░░ The job identifier is 2093 and the job result is failed.
Post
by iconnor » Thu Feb 27, 2025 2:37 am
So... in ubuntu plucky... there are issues with setting permissions on /etc/zm.conf etc... it mayhave messed up the perms there . Should be root:www-data
640
Post
by iconnor » Thu Feb 27, 2025 2:41 am
Yeah I suspect it removed the execute bit from /etc/zm.
sudo chmod 750 /etc/zm /etc/zm/conf.d
busymind
Post
by busymind » Thu Feb 27, 2025 2:50 am
BEFORE UPGRADE
root@zoneminder:~# ls -la /etc/zm/*
-rw-r----- 1 root www-data 1827 Feb 4 15:24 /etc/zm/zm.conf
/etc/zm/conf.d:
total 20
drwxr-xr-x 2 root root 4096 Feb 26 18:21 .
drwxr-xr-x 3 root root 4096 Feb 26 18:21 ..
-rw-r--r-- 1 root root 2711 Feb 4 15:24 01-system-paths.conf
-rw-r--r-- 1 root root 395 Feb 4 15:23 02-multiserver.conf
-rw-r--r-- 1 root root 740 Feb 4 15:23 README
total 16
drwxr-xr-x 92 root root 4096 Feb 26 18:45 ..
drwxr-xr-x 2 root root 4096 Feb 26 18:21 conf.d
-rw-r----- 1 root www-data 1827 Feb 4 15:24 zm.conf
root@zoneminder:~# apt-get update and upgrade .....
AFTER UPGRADE
Could not execute systemctl: at /usr/bin/deb-systemd-invoke line 145.
total 16
drw-r----- 3 www-data root 4096 Feb 26 21:46 .
drwxr-xr-x 92 root root 4096 Feb 26 21:46 ..
drw-r----- 2 www-data root 4096 Feb 26 21:46 conf.d
-rw-r----- 1 www-data root 1827 Feb 4 15:24 zm.conf
-rw-r----- 1 www-data root 1827 Feb 4 15:24 /etc/zm/zm.conf
/etc/zm/conf.d:
total 20
drw-r----- 2 www-data root 4096 Feb 26 21:46 .
drw-r----- 3 www-data root 4096 Feb 26 21:46 ..
-rw-r----- 1 www-data root 2711 Feb 4 15:24 01-system-paths.conf
-rw-r----- 1 www-data root 395 Feb 4 15:23 02-multiserver.conf
-rw-r----- 1 www-data root 740 Feb 4 15:23 README
busymind on Thu Feb 27, 2025 3:04 am, edited 1 time in total.
