Zm 1.37.66 stopped working after update; crash reported on Debian12
Posted: Wed Feb 26, 2025 8:30 pm
Zoneminder crash after today's upgrade. Logs are filling rapidly. Debian12. I forget to take a system snapshot
[/code]
some other logs
[/code]
Get:1 https://zmrepo.zoneminder.com/debian/master bookworm/ zoneminder 1.37.66~20250226.7-bookworm [8,190 kB]
Get:2 https://zmrepo.zoneminder.com/debian/master bookworm/ zoneminder-doc 1.37.66~20250226.7-bookworm [8,482 kB]
Fetched 16.7 MB in 8s (1,995 kB/s)
Reading changelogs... Done
(Reading database ... 60045 files and directories currently installed.)
Preparing to unpack .../zoneminder_1.37.66~20250226.7-bookworm_amd64.deb ...
Unpacking zoneminder (1.37.66~20250226.7-bookworm) over (1.37.65~20250225.168-bookworm) ...
Preparing to unpack .../zoneminder-doc_1.37.66~20250226.7-bookworm_all.deb ...
Unpacking zoneminder-doc (1.37.66~20250226.7-bookworm) over (1.37.65~20250225.168-bookworm) ...
Setting up zoneminder-doc (1.37.66~20250226.7-bookworm) ...
Setting up zoneminder (1.37.66~20250226.7-bookworm) ...
detected systemd
Warning: The unit file, source configuration file or drop-ins of zoneminder.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Detected db service is mariadb.service
Checking for db
Db exists.
Updating permissions for user zmuser@localhost
Initiating database upgrade to version 1.37.66 from version 1.37.65
Upgrading database to version 1.37.66
Upgrading DB to 1.37.66 from 1.37.65
Database successfully upgraded to version 1.37.66.
Database upgrade to version 1.37.66 successful.
Freshening configuration in database
Migratings passwords, if any...
Loading config from DB 242 entries
Saving config to DB 242 entries
Done Updating
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for man-db (2.11.2-2) ...
2025-02-26T15:34:28.024388-05:00 zoneminder kernel: [18840.017931] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:28.027962-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:28 2826 [Warning] Aborted connection 2826 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:29.296366-05:00 zoneminder kernel: [18841.290606] zmc[7997]: segfault at 0 ip 00007fa752667c77 sp 00007ffcae251190 error 4 in libc.so.6[7fa752645000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T15:34:29.296409-05:00 zoneminder kernel: [18841.290634] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:29.299928-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:29 2829 [Warning] Aborted connection 2829 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:32.756375-05:00 zoneminder kernel: [18844.749528] zmc[8001]: segfault at 0 ip 00007f36ac867c77 sp 00007ffc0745ee40 error 4 in libc.so.6[7f36ac845000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T15:34:32.756408-05:00 zoneminder kernel: [18844.749555] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:32.758899-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:32 2834 [Warning] Aborted connection 2834 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:33.108318-05:00 zoneminder kernel: [18845.102162] zmc[8005]: segfault at 0 ip 00007ff9a8e67c77 sp 00007ffd458ea960 error 4 in libc.so.6[7ff9a8e45000+155000] likely on CPU 3 (core 1, socket 1)
2025-02-26T15:34:33.108351-05:00 zoneminder kernel: [18845.102192] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:33.108355-05:00 zoneminder kernel: [18845.102755] zmc[8006]: segfault at 0 ip 00007fa06c867c77 sp 00007ffee8b79da0 error 4 in libc.so.6[7fa06c845000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T15:34:33.108357-05:00 zoneminder kernel: [18845.102780] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:33.110717-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:33 2839 [Warning] Aborted connection 2839 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:33.112204-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:33 2840 [Warning] Aborted connection 2840 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:34.392396-05:00 zoneminder kernel: [18846.386339] zmc[8009]: segfault at 0 ip 00007fda00267c77 sp 00007fffcd610730 error 4 in libc.so.6[7fda00245000+155000] likely on CPU 1 (core 1, socket 0)
2025-02-26T15:34:34.392445-05:00 zoneminder kernel: [18846.386368] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:34.395528-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:34 2843 [Warning] Aborted connection 2843 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:38.676351-05:00 zoneminder kernel: [18850.671828] zmc[8011]: segfault at 0 ip 00007f8f75467c77 sp 00007ffff6eb32e0 error 4 in libc.so.6[7f8f75445000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T15:34:38.676386-05:00 zoneminder kernel: [18850.671856] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:38.681697-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:38 2846 [Warning] Aborted connection 2846 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
2025-02-26T15:34:39.960422-05:00 zoneminder kernel: [18851.954464] zmc[8013]: segfault at 0 ip 00007f99e8067c77 sp 00007fffe0f6cfb0 error 4 in libc.so.6[7f99e8045000+155000] likely on CPU 0 (core 0, socket 0)
2025-02-26T15:34:39.960458-05:00 zoneminder kernel: [18851.954492] Code: 89 d7 48 89 74 24 10 85 c9 0f 85 b4 02 00 00 83 ff 01 0f 84 9b 00 00 00 83 ff 24 0f 87 92 00 00 00 48 8b 5c 24 08 49 8b 48 68 <48> 0f be 13 48 89 d0 f6 44 51 01 20 74 16 0f 1f 00 48 0f be 53 01
2025-02-26T15:34:39.963945-05:00 zoneminder mariadbd[601]: 2025-02-26 15:34:39 2849 [Warning] Aborted connection 2849 to db: 'zm' user: 'zmuser' host: 'localhost' (Got an error reading communication packets)
some other logs
2025-02-26T15:39:01.908000-05:00 zoneminder CRON[8489]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
2025-02-26T15:39:30.378553-05:00 zoneminder systemd[1]: Starting phpsessionclean.service - Clean php session files...
2025-02-26T15:39:30.711234-05:00 zoneminder systemd[1]: phpsessionclean.service: Deactivated successfully.
2025-02-26T15:39:30.711685-05:00 zoneminder systemd[1]: Finished phpsessionclean.service - Clean php session files.
2025-02-26T15:42:54.525276-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Got signal 11 (Segmentation fault), crashing]
2025-02-26T15:42:54.529370-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Signal address is (nil), from 0x7f67c8667c77]
2025-02-26T15:42:54.530189-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Got signal 11 (Segmentation fault), crashing]
2025-02-26T15:42:54.530565-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Signal address is (nil), from 0x7fd120667c77]
2025-02-26T15:42:54.530818-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xc9dfe) [0x564ee3b3bdfe]]
2025-02-26T15:42:54.531070-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xc9dfe) [0x558b1f5cbdfe]]
2025-02-26T15:42:54.531303-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7fd12065b050]]
2025-02-26T15:42:54.531558-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(+0x48c77) [0x7fd120667c77]]
2025-02-26T15:42:54.531809-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x5f703) [0x564ee3ad1703]]
2025-02-26T15:42:54.532138-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 1: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7f67c865b050]]
2025-02-26T15:42:54.532497-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x6b256) [0x564ee3add256]]
2025-02-26T15:42:54.532813-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(+0x48c77) [0x7f67c8667c77]]
2025-02-26T15:42:54.533105-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xcc6bc) [0x564ee3b3e6bc]]
2025-02-26T15:42:54.533378-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0x143b) [0x564ee3aa0a1b]]
2025-02-26T15:42:54.533678-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x5f703) [0x558b1f561703]]
2025-02-26T15:42:54.533976-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7fd12064624a]]
2025-02-26T15:42:54.534255-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7fd120646305]]
2025-02-26T15:42:54.534593-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x6b256) [0x558b1f56d256]]
2025-02-26T15:42:54.534872-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace 9: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x31961) [0x564ee3aa3961]]
2025-02-26T15:42:54.534998-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 5: /usr/lib/zoneminder/cgi-bin/nph-zms(+0xcc6bc) [0x558b1f5ce6bc]]
2025-02-26T15:42:54.535157-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
2025-02-26T15:42:54.535321-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [and execute the following command for more information:]
2025-02-26T15:42:54.535427-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0x143b) [0x558b1f530a1b]]
2025-02-26T15:42:54.535606-05:00 zoneminder zms_m1[8564]: ERR [zms_m1] [addr2line -Cfip -e /usr/lib/zoneminder/cgi-bin/nph-zms 0xc9dfe 0x5f703 0x6b256 0xcc6bc 0x31961]
2025-02-26T15:42:54.535720-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 7: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7f67c864624a]]
2025-02-26T15:42:54.535891-05:00 zoneminder zms_m1[8564]: FAT [zms_m1] [Got signal 11 (Segmentation fault), crashing]
2025-02-26T15:42:54.536007-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 8: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f67c8646305]]
2025-02-26T15:42:54.536362-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace 9: /usr/lib/zoneminder/cgi-bin/nph-zms(+0x31961) [0x558b1f533961]]
2025-02-26T15:42:54.536496-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [Backtrace complete, please install debug symbols (typically zoneminder-dbg)]
2025-02-26T15:42:54.536697-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [and execute the following command for more information:]
2025-02-26T15:42:54.536839-05:00 zoneminder zms_m2[8563]: ERR [zms_m2] [addr2line -Cfip -e /usr/lib/zoneminder/cgi-bin/nph-zms 0xc9dfe 0x5f703 0x6b256 0xcc6bc 0x31961]
2025-02-26T15:42:54.537006-05:00 zoneminder zms_m2[8563]: FAT [zms_m2] [Got signal 11 (Segmentation fault), crashing]
