I have a problem with ZMES since the upgrade to version 1.36.35, the events are detected but then ZMES does not identify anything to me.
The logs send me this message.
ars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:15 PARENT: checkEvents() new events found=1
mars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:15 PARENT: There are 1 new Events to process
mars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:15 PARENT: Forked process:1495816 to handle alarm eid:14414
mars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:15 |----> FORK:Camera entree (4), eid:14414 Adding event path:/media/motion/events/4/2025-03-0>
mars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:15 |----> FORK:Camera entree (4), eid:14414 Invoking hook on event start:'/var/lib/zmeventnoti>
mars 01 13:19:20 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in index at /usr/bin/zmeventnotification.pl line 3195.
mars 01 13:19:20 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in index at /usr/bin/zmeventnotification.pl line 3197.
mars 01 13:19:22 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in string eq at /usr/bin/zmeventnotification.pl line 3672.
mars 01 13:19:22 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in string eq at /usr/bin/zmeventnotification.pl line 3834.
mars 01 13:19:22 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in string eq at /usr/bin/zmeventnotification.pl line 3935.
mars 01 13:19:26 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in index at /usr/bin/zmeventnotification.pl line 3197.
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:18 |----> FORK:Camera entree (4), eid:14414 parse of hook: and [] from
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:18 |----> FORK:Camera entree (4), eid:14414 hook start returned with text: json:[] exit:1
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:20 |----> FORK:Camera entree (4), eid:14414 rules: Checking rules for alarm caused by eid:1441>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:20 |----> FORK:Camera entree (4), eid:14414 rules: No rules found for Monitor, allowing:4
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:20 |----> FORK:Camera entree (4), eid:14414 Matching alarm to connection rules...
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:22 |----> FORK:Camera entree (4), eid:14414 For 4 (Camera entree), SHM says: state=1, eid=14414
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: INF:2025-03-01,13:19:22 |----> FORK:Camera entree (4), eid:14414 Event 14414 for Monitor 4 has finished
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:22 |----> FORK:Camera entree (4), eid:14414 Event end object is: state=>pending with cause=>Mo>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: INF:2025-03-01,13:19:24 |----> FORK:Camera entree (4), eid:14414 end hooks/use hooks not being used, going to directl>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:26 |----> FORK:Camera entree (4), eid:14414 rules: Checking rules for alarm caused by eid:1441>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:26 |----> FORK:Camera entree (4), eid:14414 rules: No rules found for Monitor, allowing:4
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: INF:2025-03-01,13:19:26 |----> FORK:Camera entree (4), eid:14414 Not sending event end alarm, as we did not send a st>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:30 |----> FORK:Camera entree (4), eid:14414 exiting
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:30 |----> FORK:Camera entree (4), eid:14414 Ending process:1495816 to handle alarms
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:15 PARENT: ---------->Tick END (active forks:1, total forks:10, active hooks: 0)<--------------
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: ----------> Tick START (active forks:1, total forks:10, active hooks: 0 running for>
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: After tick: TOTAL: 0 , ES_CONTROL: 0, FCM+WEB: 0, FCM: 0, WEB: 0, MQTT:0, invalid >
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: RAW TEXT-->update_parallel_hooks--TYPE--add
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: RAW TEXT-->update_parallel_hooks--TYPE--del
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: There are 1 active child forks & 0 zm_detect processes running...
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: We've already worked on Monitor:4, Event:14414, not doing anything more
