I noticed this anomaly in my logs (I think since I did my last update) :
#systemctl status zoneminder
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2025-03-03 08:24:29 CET; 8s ago
Process: 793906 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=1/FAILURE)
CPU: 140ms
mars 03 08:24:39 video systemd[1]: Starting ZoneMinder CCTV recording and surveillance system>
mars 03 08:24:39 video4 su[793935]: (to www-data) root on none
mars 03 08:24:39 video su[793935]: pam_unix(su:session): session opened for user www-data(uid>
mars 03 08:24:40 video su[793935]: pam_unix(su:session): session closed for user www-data
mars 03 08:24:40 video su[793938]: (to www-data) root on none
mars 03 08:24:40 video su[793938]: pam_unix(su:session): session opened for user www-data(uid>
mars 03 08:24:40 video su[793938]: pam_unix(su:session): session closed for user www-data
mars 03 08:24:41 videoc systemd[1]: zoneminder.service: Control process exited, code=exited, s>
mars 03 08:24:41 video systemd[1]: zoneminder.service: Failed with result 'exit-code'.
mars 03 08:24:41 video systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance>
Do you have any idea for this problem?
if I try to start the service manually, it's the same (systemctl start zoneminder)
zoneMinder v1.36.35 runs on GNU/Debian 11 stable.
Thank you for your help
Melsiar
Re: Failed to start ZoneMinder CCTV recording and surveillance
# journalctl -xu zoneminder.service
