Lost events (from database) during move filter (ubuntu 22.04 zm 1.36.35)
ameterasu
Post by ameterasu »
Hey All,
I'm currently having an issue with move filters.
I have 2 storage areas, saving only videos to cache, then with 2 filters, move from cache to big drives at 90%, purge from big drives at 95%.
I get many errors like below from filter_4. I believe this is the move filter.
I've checked a couple of these events, they are not available on the cache, but available on the big drives.
When i select one of these events and look into details, I find these errors (maybe helps)
Can someone pinpoint how to solve this? I'm not sure but maybe if the database is not updated, then the big drives have events with no connection and they will never be purged?
ameterasu
Re: Lost events (from database) during move filter (ubuntu 22.04 1.36.35)
Post by ameterasu »
I could not upload 4th picture, so here is the filtered logs with one of the problematic events.
There is also a update disk space filter inplace if it makes any difference.
ameterasu
Post by ameterasu »
Also investigated what is going on events prior to this and after. Attached 2 screenshots of before and after.
I think its only about database not being updated about the move. Prior and after events are all located at the bigdisk and the referance is correct. These 4 events are available in the correct place. But ZM still thinks they are at cache. But why?
Edit: just saw that the time modification is much earlier on these 4 events. Maybe a clue?
