IN-9420 2K+: Not working with audio disabled
Posted: Tue Mar 11, 2025 3:38 pm
Hi there,
we have been using Zoneminder 1.36.35 together with Instar cameras for a long time and are very satisfied.
Now we are testing the IN-9420 2K+ (current firmware) for the first time and have the following issue: As long as audio is activated on the camera (Multimedia -> Audio), everything works fine. However, as soon as we disable audio, we no longer get any pictures from the camera. We then find these messages in the logs:
What can we do about this?
Thanks a lot for your support and many greets
Stephan
Mar 11 16:26:39 <hostname> zmc_m7[2388902]: INF [zmc_m7] [Unable to read packet from stream 0: error -541478725 "End of file".]
Mar 11 16:26:39 <hostname> zmc_m7[2388902]: ERR [zmc_m7] [Failed to capture image from monitor 7 <monitor name> (1/1)]
Mar 11 16:26:39 <hostname> zmc_m7[2388902]: INF [zmc_m7] [<monitor name>: image_count:1448 - Closing event 2429651, shutting down]
Mar 11 16:26:39 <hostname> zms_m7[2388414]: ERR [zms_m7] [Monitor shm is not connected]
Mar 11 16:26:50 <hostname> zmc_m7[2388902]: ERR [zmc_m7] [Unable to open input rtsp://ip:554/livestream/11 due to: Invalid data found when processing input]
Mar 11 16:27:02 <hostname> zmc_m7[2388902]: ERR [zmc_m7] [Unable to open codec for audio stream from rtsp://ip:554/livestream/11]
Mar 11 16:27:02 <hostname> zmc_m7[2388902]: ERR [zmc_m7] [Failed to prime capture of initial monitor]
Mar 11 16:27:24 <hostname> zms_m7[2388414]: ERR [zms_m7] [Monitor shm is not connected]
Mar 11 16:27:26 <hostname> zms_m7[2388414]: ERR [zms_m7] [Can't open memory map file /dev/shm/zm.mmap.7: No such file or directory]
Mar 11 16:27:26 <hostname> zms_m7[2388414]: ERR [zms_m7] [Unable to connect to monitor id 7 for streaming]
Stephan
