Page 1 of 1
Reolink PT Ultra camera
Posted: Fri Mar 21, 2025 11:49 am
by hornetster
Anyone know/have experience with this camera and Zoneminder??
Trying to figure out if there are any "not too expensive" battery/wifi cameras that will work successfully with Zoneminder....
Anyone?
Thanks.
Re: Reolink PT Ultra camera
Posted: Sat Mar 22, 2025 9:41 pm
by dougmccrary
If the camera can stream continuosly, it can work.
I don't think such a thing exists "off the shelf" due to low battery capacity.
AFAIK, you'd need to add your own battery/solar array to get that capacity, which means you don't need the camera itself to be battery.
Posted: Sun Mar 23, 2025 3:10 pm
by mikb
dougmccrary wrote: Sat Mar 22, 2025 9:41 pm If the camera can stream continuosly, it can work.
I don't know if ZM would/could ever be "adjusted" to cope with the behaviour of cameras like these. The constant disappearance/disconnection which is "normal power saving operation" to the camera is nuisance/error behaviour to ZM.
The other thing to watch out for is cheap cameras that will _only_ stream out via WiFi to some "free" (currently) cloud service, which then sends the stream back to you. Four main faults with that scenario: a) Privacy, b) Efficiency/Resilience of streaming out-and-back, c) Free now -- pay-for later? d) "Sorry, service closed down, please buy new camera!"
