ZM-compatible 360°C
Hoythmitt
ZM-compatible 360°C
Post by Hoythmitt »
One of my goals is to install a 360-degree PoE camera on top of my house.
You can check if it works with ZoneMinder here.
We call it "PoE" since it just needs one wire to be connected.
Since the roof is out of reach and there are no moving parts, I think several sensors would provide a better panoramic image than a PTZ.
My budget should not go over $800 unless absolutely necessary, but I am open to spending up to $1,000 for a valid cause.
Do you have any suggestions? Much obliged.
Re: ZM-compatible 360°C
Hikvision or one of it's clones has some that are cheapish.
