how can i add / configure the gameport on my mandrake system?
i´ve tested to load some joystick modules. but i don´t really know which one is correct?
there is no /dev/js0 or /dev/input/js0 port?
best regards, Holger
Gameport
It's been a while but I would Google for "jscal jstest" and see what shows up in the groups section. I added Joystick support for a Debian system years ago and those two utilities are used to calibrate and test the joystick.
What do you plan on using the joystick for? PTZ camera control? That would be cool.
