Which version to install?
joea
Post by joea »
Just installed on Pi 4.
Is this where I should be posting "get things working" questions? What is the "running" version?
Versions as shown:
zm snip.PNG (35.55 KiB) Viewed 7410 times
burger
Re: Which version to install?
Post by burger »
You should install the stable release of Zoneminder which is 1.36. Stable will be even numbers (36,38,40). Do not install the development version (odd numbers) unless you know what you are doing.
fastest way to test streams:
