Montage View working (11 cams) but has 1 blank panel in the middle (like a camera should be there but its not a camera)
GingerDave
Post by GingerDave »
Hello All,
I hope someone can help. My Zoneminder setup is working fine except one minor thing on the Montage View - I have one blank window/panel (would be a camera view) however all my cameras aare displaying fine (including new ones I add). I have 11 cameras all working fine - after 6 cameras shown there is a blank (black) panel where one would be displayed and then my cameras carry on - camera 7 to 11. Its quite annoying as when I add a 12 camera it makes me scroll down for no reason (if the empty black panel was not there they would all fit on 1 screen). I am on 1.36.35 on Ubuntu - I have tried several browsers but they all show the same - any help you could give to solve this would be appreciated. Many Thanks Dave.
Re: Montage View working (11 cams) but has 1 blank panel in the middle (like a camera should be there but its not a came
It may be that one of the monitors is 1 pixel taller than the other and is causing layout to break as you describe. Try sorting them differently. 1.37 does a much better job of this
