zmu not working?
marcjw
zmu not working?
Post by marcjw »
I just updated to 1.37.66 from 1.35 and have no complaints so far but I can't seem to get zmu to work.
This used to work in 1.35:
sudo -u www-data zmu -m1 -D -U <user> -P <password>
No errors; it just doesn't disable it. It also used to change the change the activity button from green to orange but not now.
Known issue? Am I doing it wrong?
Re: zmu not working?
The meaning of the various commands has changed... In 1.36 we have
-E, --enable : Enable detection, wake monitor up
-D, --disable : Disable detection, put monitor to sleep
-u, --suspend : Suspend detection, useful to prevent bogus alarms when panning etc
-r, --resume : Resume detection after a suspend
What's the difference between enable/resume and disable/suspend? The code implementing them was confused as well. I suspect many developers over the years got confused. SO I changed it. Now we have:
-E, --enable : Enable capture, wake monitor up
-D, --disable : Disable capture, put monitor to sleep
-u, --suspend : Suspend motion detection, useful to prevent bogus alarms when panning etc
-r, --resume : Resume motion detection after a suspend
-D should stop capturing completely.
Of course, as you noticed, it does not. I guess I never implemented that. Fix incoming. Packages building...
marcjw
Post by marcjw »
I found your emergency build and it's good news - the zmu -D option now works works! Unfortunately, there seems to be a daemon gremlin that wants to keep restarting it after a few seconds. That is definitely not desired.
06/13/2025 19:43:19.392542 zmwatch[14468].WAR [main:160] [Restarting capture daemon for Kitchen, time since last capture 46 seconds (1749861799-1749861753)]
06/13/2025 19:45:19.766598 zmwatch[14468].WAR [main:160] [Restarting capture daemon for Kitchen, time since last capture 46 seconds (1749861919-1749861873)]
06/13/2025 19:47:20.014745 zmwatch[14468].WAR [main:160] [Restarting capture daemon for Kitchen, time since last capture 47 seconds (1749862040-1749861993)]
06/13/2025 19:47:40.351236 zmwatch[14468].WAR [main:139] [Restarting capture daemon for 1 Kitchen, no image since startup. Startup time was 0 - now 1749862060 > 45]
06/13/2025 19:49:20.494701 zmwatch[14468].WAR [main:160] [Restarting capture daemon for Kitchen, time since last capture 47 seconds (1749862160-1749862113)]
iconnor wrote: Fri Jun 13, 2025 1:37 pm The meaning of the various commands has changed... In 1.36 we have
edited - typo
