Amcrest IP4M-1053E PTZ control
wp6529
Post by wp6529 »
Has anyone been successful in getting PTZ control for an Amcrest IP4M-1053E camera working?
Re: Amcrest IP4M-1053E PTZ control
Should be the same for any Amcrest PTZ cam
Controlable (checked)
Control Type - Amcrest HTTP API
Control Address - http://user:password@cam-IP-Address
Set the preset positions in the camera GUI (1-5)
Note: I have the best success using the "admin" user in the cam.
wp6529
Post by wp6529 »
I have just tested and it does not work. The camera's own GUI of course moves it around just fine but no-go on the control address.
Software Version
V2.623.00AC005.0.R.R4.1219.9A.NR, Build Date: 2021-08-13
WEB Version
3.2.1.813318
ONVIF Version
16.12(V2.4.3.580229)
PTZ Version
V2.301.0000000.22.RHNZ_190923_33333
wp6529
Post by wp6529 »
I got it working after finally getting a chance to spend more time looking at it. Auhentication issue bypassed by disabling ssl, at some point I might try to get ssl working properly but it's not terribly important here.
Thanks.
