Per event ftp uploads
Posted: Fri May 21, 2004 9:49 pm
hi.
it would be great to have a way to upload the events one by one.
so when you click to see an event, should appear a "upload" link on its screen, then when you click in this link, the upload is done.
this would be great to make zoneminder works with webcdcreator.
the idea is : to use one Directory to all events uploaded.
then, you select the event, upload it to itself computer running zoneminder (and a ftp server). then the event will be at that directory.
then we configure webcdcreator to only see THAT directory.
after that, you just start a new cd writting session. when the burn itself ends, the webcdwrite could ERASE that directory.
this is a GREAT WAY to make ZM burn CDs. and it just needs one little change.
thanks phil
victor diago
thanks phil
victor diago
