PurgeWhenFull do not work
macguru
Post by macguru »
I have a problem with currently running ZoneMinder 1.19.4 in our office. I have set up to delete old unarchived events (1000 max) when disk is full 70%. However, my disk is already 82% full, and old events are still here. Please note that I have ZM_OPT_FAST_DELETE "When deleting events should the client only delete the database records for speed" option off. Additionally, I have changed PurgeWhenFull setting to 1-filter expression (disk usage %), adjusted max disk usage ratio to 80% when disk was 79% full, nothing helped. I have "Automatically delete all matches" in PurgeWhenFull on, verified.
Thanks in advance for any suggestion(s).
Andrei (aka MacGuru)
zoneminder
Site Admin
Post by zoneminder »
Hi Andrei,
Have you looked in zmfilter.log to see if anything unusual is going on? What distro are you using by the way?
Phil,
