I would like to make you a question.
I'm only using 16 of the inputs of a 8 bttv chips card.
When i'm using two cams in each device, on one of the cams the image flicks with the other image on the same device.
It mainly shows the right image, but in each ~3 seconds it shows very quickly the other cam on the same device.
Do you think this is a zoneminder issue?
I also am having this error message:
Jun 4 12:08:42 vigilancia zmc-d1[27899]: WAR [Buffer overrun at index 1 ]
and
Jun 4 12:08:05 vigilancia zma-m11[29208]: WAR [Approaching buffer overrun, consider increasing ring buffer size]
strange behavior
- victor_diago
- Contact:
hi. try to downgrade fps capture rate, increase buffers AND shared memory.
specially, increase ring buffer size. in Approaching buffer overrun, consider increasing ring buffer size] we can see that the software itself ask you to do that. one more look at that and you solve your problems
it´s not a zm related problem, since im using it with 16 cameras right now and thats all right..
another thing. are you brazilian ?
victor diago
victor diago
