Pixord equipment - somewhat OK
el_flynn
Post by el_flynn »
I've had some success using the Pixord range of network cameras with ZoneMinder. However, sometimes ZM can't seem to pick up the image stream from the cameras, whilst at other times everything runs smoothly.
The following network cameras were successfully configured:
1) Pixord 120
2) Pixord 200
3) Pixord 205
4) Pixord 4000 Video Server
If you're planning to use network cameras, make sure you've got all the requirements and libs. After spending many hours in frustration, I scanned /var/log/messages and found out I was missing libpcre.a (which could have been circumvented, I suppose, had I RTFM heheh)
Cheers.
kulla
Re: Pixord equipment - somewhat OK
Post by kulla »
Can you please specify how you get stream from cameras?
Tnx
ynn
Post by ynn »
how did you find pixord camra? are they any good?
thanks.
hmazzeo
Configuration???
Post by hmazzeo »
I am using cameras PIXORD, although not yet I can make record them nor visualize.
You could say to me as it is the configuration that you applied camaras so that they work?
Thank you very much
sipi
Post by sipi »
I tested Pixord 205 IP camera too. My setup config is
username:password@camera_ip_address
80
/getimage?camera=1&fmt=full
24 bit color
640
480
