Hi All,
Is it possible to have web interface to set pre-set times for starting and stopping modect, has anyone been doing this with cron, if so how have you set this for /dev/video0(1) and the like
regards
fred
start stop time event for modect
- zoneminder
- Site Admin
- Contact:
At least two ways you could possibly do this spring to mind! I am assuming that when you don't want 'modect', you want either 'monitor' or nothing at all.
1) Make the monitors you want this to apply to to be 'triggered', then in your cron just do
perl zmdc.pl start (or stop) zma -m 1 (or 2 etc)
this will have the effect of starting and stopping the analysis daemons entirely whilst leaving the capture daemons running.
2) Set all your monitors to the states you want them to be in at one point in the day and click on the 'Running' link in the console. Then save these monitor states with a name of your choice, e.g. 'Modecting'. Change the monitors to be how you'd like them at the other time of day and save that as something else, e.g. 'Monitoring'. Then in your cron you can say
perl zmpkg.pl Modecting (or Monitoring)
which should work as well.
Method (1) is simpler and only the appropriate daemons are started and stopped. Method (2) is a bit neater but the system basically gets restarted each time which may not be what you want.
I'm sure there are probably other ways too (e.g. use X.10 and a timer!).
Phil,
Phil,
- lazyleopard
