Sort by Duration doesn't seem to work...
- lazyleopard
I'm now using sort by Frames rather than sort by Duration, as I just noticed the latter doesn't seem to do what I expect, but seems to sort by date/time instead. (Using 1.19.3)
Rick Hewett
- lazyleopard
Which version are you using?
Select a list of events (sorted by default Date/Time)
Change to "Duration" and hit "Select"
Change to "Frames" and hit "Select"
Id Name Monitor Time(v) Duration Frames Alarm Frames Total Score Avg. Score Max. Score Mark
30344 Event-30344 Door 06/25 11:43:29 12.61 58 37 3478 94 168
30340 Event-30340 Door 06/25 11:38:03 0.70 24 3 3 1 1
30338 Event-30338 Door 06/25 11:30:57 3.16 31 10 1143 114 158
30333 Event-30333 Door 06/25 11:21:05 1.40 26 5 342 68 116
30322 Event-30322 Door 06/25 11:10:33 3.16 31 10 753 75 129
Id Name Monitor Time Duration Frames Alarm Frames Total Score Avg. Score Max. Score Mark
Id Name Monitor Time Duration Frames(v) Alarm Frames Total Score Avg. Score Max. Score Mark
29419 Event-29419 Door 06/24 13:53:40 19.27 77 45 3554 78 163
30206 Event-30206 Door 06/25 09:33:32 12.97 59 32 2251 70 122
30207 Event-30207 Door 06/25 09:33:51 11.21 54 31 2777 89 140
30259 Event-30259 Door 06/25 10:04:30 5.60 38 10 1111 111 149
Rick Hewett
- lazyleopard
- lazyleopard
Ok... Further investigation reveals:
1) If I select "Duration" from the drop-down in the "Sort by" part of the "Filter" window, and then hit "Submit" in the same window, the events end up sorted in the default order.
2) If I click on the "Duration" title in the "Events" list window then the sort happens as expected.
Rick Hewett
- zoneminder
- Site Admin
- Contact:
- lazyleopard
- zoneminder
- Site Admin
- Contact:
I've had a look at this now and have found the problem. It's fixed in the main development tree now but if you want to patch your own installation the easiest thing to do is edit zm_funcs.php, then go to line 450 or so and look for the line
case 'Secs' :
$sort_column = "E.Length";
break;
and add an extra line so it now appears thus
case 'Secs' :
case 'Length' :
break;
then save and exit.
Phil,
case 'Secs' :
break;
case 'Secs' :
case 'Length' :
break;
then save and exit.
Phil,
- lazyleopard
