Using zoneminder zms as remote camera
Hi Everyone,
As suggested I am trying to use one "slave" ZM installation as the source for another "master" installation.
On the master ZM box I have setup a remote source:
IP: 192.168.160.200
port: 80
path: /cgi-bin/zms?mode=jpeg&monitor=5&scale=100&maxfps=2
and I have tried
path: /cgi-bin/nph-zms?mode=jpeg&monitor=5&scale=100&maxfps=2
When I click to view the cam I get cambozola just sit there on its opening credits screen and no action. If I visit http://192.168.160.200/cgi-bin/nph-zms? ... 0&maxfps=2 I get a stream of stuff that I presume is a jpeg stream?
Any ideas of where to go from here appriciated?
Pete
IP: 192.168.160.200
port: 80
and I have tried
Pete
if it helps... Cambozola
I have tried the latest Cambozola 0.34 and 0.22 both do the same - it just sits there
Pete
Pete
Working remote zoneminder ?
Sorry to go on.....
Would someone kindly provide and example of using a remote ZM installation as a source for a remote camera - the ones above don't work and this is doing my nut in!!
Has anyone tried? tried and failed?
What about authentication into Zoneminder - can I link to a camera stream that is on an authenticated Zoneminder? I have turned all authentication off, deleted all cameras and still no luck.
Sooo close!
Sooo close!
- zoneminder
- Site Admin
- Contact:
still not working
Sorry for the delay in answering i have been on hols.
I still can't use a master installation to view a slave stream.
both boxes are running 1.19.4 and work with local cameras. I have removed the local camera from the master box and just setup a remote stream to:
192.168.160.200/cgi-bin/zms?Zode=jpeg&monitor=3&scale=100&maxfps=15
If I use nph-zms it complains
Jul 23 13:21:14 moksha zmc-m8[28910]: ERR [Unable to extract HTTP status from header]
and with zms on its own it has no errors but it just sits there at 0fps not doing anything - I get this in the logs
Jul 23 13:27:03 moksha zms[31768]: INF [Debug Level = 0, Debug Log = ]
This is driving me insane, and i now have a boss leaning on me - any help appriciated.
Pete
Pete
Well, just to comfort you: tried exactly the same thing and got the same results as you. Since the zm-docs are kind of "lean" in respect to networked cams using zms, I have no idea what to do.
Just some additional infos:
1) Using Cambozola and both master and slave configured to use greyscale I get just the copyright message and 0.00 fps
2) Using stills and both master and slave configured to use greyscale I get a black picture which is not the content of the slave frames.
3) On the slave machine the /var/log/messages fills up with this
"Aug 4 16:33:18 serverone zms[8740]: INF [Debug Level = 0, Debug Log = ]"
About 2 of these messages per second.
4)On the master machine the /var/log/messages fills up with this
"Aug 4 16:37:03 VideoServer nph-zms[1285]: INF [Debug Level = 0, Debug Log = ]
Aug 4 16:37:03 VideoServer zmc-m5[1021]: ERR [Invalid response status 500: Internal Server Error]
Aug 4 16:37:17 VideoServer last message repeated 29 times"
The weird thing is that I have the master source path configured to use "zms" and not as the log-file shows "nph-zms".
I´ll be fiddling around with some config options and let you know about the results.
Regards
Juergen
Regards
Juergen
Still no luck
I still haven't got this sorted and am banging my head againt the wall...
I suppose wait for the next release to see if it has been fixed.
Pete
Pete
- zoneminder
- Site Admin
- Contact:
I'm trying to get this working here with no luck. I find that if I enter these values in the source fields of the monitor config window :
Remote Host Name 192.168.2.9
Remote Host Port 80
Remote Host Path /cgi-bin/nph-zms?mode=jpeg&monitor=5&scale=100&maxfps=2
I then get this as the source of the watch feed frame :
So ZM seems to be ignoring the path field and defaulting to a relative path to its own /cgi-bin/zms
OK now that I've taken time to think about it.
This is as I should expect. However I have still not been able to get it working. Questions about config that come to mind are :
Slave should have ZM_CAN_STREAM set to ?
Does it make a difference if slave uses zms or nph-zms?
Does the fps setting on master have to match the setting on slave?
All the details of a setup that works would be great.
Best regards,
Ross
Remote Host Port 80
<img src="/cgi-bin/zms?mode=jpeg&monitor=1&scale=100&maxfps=15" border="0" width="320" height="240">
Best regards,
Ross
Still no luck FWIW
I have tried various different options and still no luck.
I have an external setup ready for Phil to debug when he gets the time.
Just email me if you haven't got the details phil...
Pete
Pete
