ZM 1.19.3
OS RH9 with 2.6 kernel
BT848 Capture Card
Memory: 1165588k/1179648k available (2072k kernel code, 12940k reserved, 752k data, 396k init, 262144k highmem)
Everything had been running nicely until recently when I stopped using X on this system. Now i'm having trouble with /dev/video0 permissions.
Why is zmfix changing permissions to 20606 and 20660 which causes a permission denied error when opening /dev/video0?
Jun 27 14:12:39 gw zmfix[26816]: INF [Resetting permissions on /dev/video0 to 20606]
Jun 28 07:00:29 gw zmfix[10370]: INF [Resetting permissions on /dev/video0 to 20606]
have all been followed byJun 30 08:00:30 gw zmfix[26170]: INF [Resetting permissions on /dev/video0 to 20660]
Most of the time zmfix works properly so when I run 'gdb zmfix', it exits normally.Jun 30 08:00:14 gw zmc-d0[26157]: ERR [Failed to open video device /dev/video0: Permission denied]
Corresponding zmwatch.log shows
Restarting capture daemon ('/usr/local/bin/zmdc.pl restart zmc -d 0'), time since last capture 46186 seconds (1088370740-1088324554)
'zmc -d 0' starting at 04/06/27 14:12:20, pid = 26767
'zmc -d 0' started at 04/06/27 14:12:20
Watchdog starting at 04/06/27 14:12:45
Watchdog pausing for 30 seconds
Other info:
root@zoneminder# cat /proc/sys/kernel/shmmax
734003200
root@zoneminder# cat /proc/sys/kernel/shmall
734003200
From dmesg:
bttv0: detected: AVermedia TVCapture 98 [card=13], PCI subsystem ID is 1461:0002
bttv0: using: AVerMedia TVCapture 98 [card=13,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=000477c3 [init]
bttv0: Hauppauge/Voodoo msp34xx: reset line init [11]
bttv0: Avermedia eeprom[0x4001]: tuner=2 radio:no remote control:yes
bttv0: using tuner=2
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for MSP34xx (alternate address) @ 0x88... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv0: add subdevice "remote0"
