johabba wrote:
mpoertner:
- what distro are you using? did you have to make _ANY_ changes to get the card to work?
- what is the output of 'dmesg'?
- what is the output of 'cat /proc/interrupts'?
- what is the output of 'lsmod'?
- by 'card=77' i meant the card= value that I have been playing trying to gey my card to show a picture. Do you have any card= values in your /etc/modprobe.conf (or other module option file?)?
I am really desparate to get this card working. I only bought it because others in this forum said it and the 8-port variant works with linux.
other knowledgeable zoneminder users:
- does the blue screen mean the card is working and the camera is the prob?
- i'm worried that it doesn't even give me a picture in windoze. anyone else try this card? please tell how you got it to work.
I get a blue screen when there is no camera connected to the input. Perhaps your camera is no good? Otherwise, I would guess your card is bad and I'd have it exchanged.
I've always used Ross Melin's LiveCds and I've NEVER had to do anything. It's just always worked. I just upgraded to the livecd version 1.21.3 today and here are the answers to your other questions....
dmesg:
bttv: driver version 0.9.14 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
PCI: Found IRQ 5 for device 0000:00:09.0
PCI: Sharing IRQ 5 with 0000:00:09.1
PCI: Sharing IRQ 5 with 0000:00:10.1
bttv0: Bt878 (rev 17) at 0000:00:09.0, irq: 5, latency: 32, mmio: 0xe2011000
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffe1 [init]
bttv: readee error
bttv0: using tuner=-1
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: registered device video0
bttv0: registered device vbi0
/proc/interupts:
CPU0
0: 4280129 XT-PIC timer
2: 0 XT-PIC cascade
3: 0 XT-PIC uhci_hcd
5: 362627 XT-PIC uhci_hcd, bttv0
8: 0 XT-PIC rtc
10: 3 XT-PIC ehci_hcd, bttv1
11: 408383 XT-PIC uhci_hcd, eth0
14: 3638 XT-PIC ide0
15: 18 XT-PIC ide1
NMI: 0
LOC: 4280129
ERR: 5410
MIS: 0
lsmod:
Module Size Used by
af_packet 21768 4
via-rhine 20808 0
mii 5024 1 via-rhine
ide-cd 39904 0
loop 15592 0
via-agp 8480 1
agpgart 32552 1 via-agp
tuner 17068 0
tvaudio 21484 0
bttv 147244 1
video-buf 20292 1 bttv
i2c-algo-bit 9192 1 bttv
v4l2-common 6144 1 bttv
btcx-risc 4680 1 bttv
i2c-core 23476 4 tuner,tvaudio,bttv,i2c-algo-bit
videodev 9792 2 bttv
soundcore 9952 1 bttv
rtc 12568 0
usb-storage 72580 0
sata_vsc 6948 0
sata_via 6788 0
sata_svw 6372 0
sata_sil 7428 0
sata_promise 9156 0
megaraid 39304 0
aha152x 36880 0
a100u2w 11936 0
sg 37372 0
sr_mod 20068 0
cdrom 36924 2 ide-cd,sr_mod
ata_piix 7652 0
sd_mod 21088 0
libata 39364 6 sata_vsc,sata_via,sata_svw,sata_sil,sata_promise,ata_piix
scsi_mod 114156 9 usb-storage,sata_promise,megaraid,aha152x,a100u2w,sg,sr_mod,sd_mod,libata
usbhid 43104 0
ehci-hcd 28932 0
uhci-hcd 30800 0
usbcore 107264 6 usb-storage,usbhid,ehci-hcd,uhci-hcd
Hope this helps....
Matt
