Hi everyone,
Setting up ZoneMinder 1.19.4 on a Debian Woody box (kernel 2.4.18) with a Spectra-8 8-port capture card. The box is a P4 2.8, 512mb RAM.
I'm seeing (continuously) in /var/log/messages:
zma-m5[555]: WAR [Waiting for capture daemon]
(for all monitors, not just #5)
Digging deeper, an strace on 'zmc -d 1' gets me:
send(3, "<142>Jul 22 12:34:00 zmc-d1[667]: INF [Starting Capture]", 56, 0) = 56
rt_sigaction(SIGPIPE, {SIG_IGN}, NULL, = 0
rt_sigaction(SIGTERM, {0x8049ee0, [], 0x4000000}, {SIG_DFL}, = 0
rt_sigprocmask(SIG_BLOCK, [USR1 USR2], NULL, = 0
gettimeofday({1090463640, 352323}, {4294966696, 0}) = 0
ioctl(5, VIDIOCSCHAN, 0xbffffb3c) = 0
ioctl(5, VIDIOCMCAPTURE, 0xd1dd1c0) = 0
ioctl(5, VIDIOCSYNC, 0x8065c68) = 0
gettimeofday({1090463640, 442942}, {4294966696, 0}) = 0
gettimeofday({1090463640, 443222}, {4294966696, 0}) = 0
gettimeofday({1090463640, 443341}, {4294966696, 0}) = 0
ioctl(5, VIDIOCMCAPTURE, 0xd1dd1d0) = 0
ioctl(5, VIDIOCSYNC <unfinished ...>
For the record, my interrupts are as follows:
16: 0 IO-APIC-level bttv
17: 0 IO-APIC-level bttv
18: 60737 IO-APIC-level eth0, bttv
19: 0 IO-APIC-level bttv
xawtv can display an overlay of all inputs from this card just fine, but I can't capture from it. It complaints as follows:
ioctl: VIDIOCGCAP(BT878(ProVideo PV951),type=0xeb,chan=3,audio=1,size=48x32-924x576): ok
setformat: 16 bit YUV 4:2:2 (planar) (924x576): failed
v4l: setformat
At startup, it also throws these:
gd: config 384x288 win=1200043
v4l: setformat
v4l: capture probe 32 bit TrueColor (LE: bgr-)... ioctl: VIDIOCMCAPTURE(0,fmt=5,size=48x32): ok
v4l: timeout (got SIGALRM), hardware/driver problems?
ioctl: VIDIOCSYNC(0): Interrupted system call
failed
This is probably something fairly simple, but I'm not well versed with V4L, so I can't see it
Suggestions most welcome.
V4L/Spectra-8/Zoneminder problem :-(
I had this same error...
I moved my BTTV capture card to a PCI slot with a higher priority (I used slot 1), and the problem went away!
