Page 1 of 1
Zone Minder Chrashed
Posted: Fri Jul 23, 2004 11:47 am
by wheelbarrow
The PC i use for zoneminder chrashed today so i have to reboot with the reset switch.
It all came back so i was happy. However when i got to the zone minder page i can login ok but get the following error.
Got error 134 from table handler
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /var/www/html/zm/zm_html_view_console.php on line 41
I guess the database has got corupted.
Is the a quick fix for this or should i rebuild the machine from the live cd.
Regards
Paul
Posted: Fri Jul 23, 2004 2:40 pm
by rdmelin
This will repair any damaged tables. Run as root
myisamchk --silent --force --fast --update-state -O key_buffer=64M \
-O sort_buffer=64M -O read_buffer=1M -O write_buffer=1M \
/var/lib/mysql/*/*.MYI
Hope this helps.
Ross
Posted: Fri Jul 23, 2004 4:30 pm
by wheelbarrow
Thanks Ross,
This has got the database back.
Regards
Paul
