default monitor size in montage view
Im in the middle of setting up a 3 camera cctv system using zonealarm. There are going to be a view viewing stations around the house, consisting of an old laptop with a 13" screen, a 15" screen connected to the main zoneminder machine, and a newer 15" laptop in another room. Looking at the settings it appears that there is one general setting for web_montage width and height, so I think I may be facing a problem as in order to get the right size image on the 2 larger screens, the smaller screen wont be able to display all camera's at the same size. Am I missing a setting which would allow each viewing machine to use a different size, or if not what is the recommended compromise to enable best viewing on all machines?
