No streaming video
Ben
No streaming video
Post by Ben »
Hi, I have Zm 1.19.4 running. Only I still have no streaming video. The picture is refreshing every 15 seconds.. I can't select streaming. I search the forum for a couple of day's and I think I have try everything. I will send my install log after ./confige and my zmdc.log
[root@gateway zm-1.19.4]#
./configure
--with-mysql=/usr
--with-webdir=/var/www/html/zm
--with-cgidir=/var/www/cgi-bin
--with-ffmpeg=/usr/local/include/ffmpeg
--with-lame=/usr/bin
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
configure: WARNING: You can call configure with the --with-webuser option.
This tells configure what the user name of the web user is if it is not the default of 'apache'.
e.g. --with-webuser=apache or --with-webuser=web
configure: WARNING: You can call configure with the --with-webgroup option.
This tells configure what the group name of the web group is if it is not the default of 'apache'.
e.g. --with-webgroup=apache or --with-webgroup=web
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether make sets $(MAKE)... (cached) yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking how to run the C++ preprocessor... g++ -E
checking pcre/pcre.h usability... yes
checking pcre/pcre.h presence... yes
checking for pcre/pcre.h... yes
checking pcre.h usability... no
checking pcre.h presence... no
checking for pcre.h... no
checking whether round is declared... yes
checking whether strsignal is declared... yes
checking for jpeg_start_compress in -ljpeg... yes
checking for compress in -lz... yes
checking for dlsym in -ldl... yes
checking for mysql_init in -lmysqlclient... yes
checking for pcre_compile in -lpcre... yes
checking for avcodec_init in -lavcodec... yes
checking for av_new_stream in -lavformat... yes
checking for lame_init in -lmp3lame... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating web/Makefile
config.status: creating scripts/Makefile
config.status: creating db/Makefile
config.status: creating zmconfig.pl
config.status: creating config.h
config.status: executing depfiles commands
checking for zmconfig.txt... no
configure: WARNING: Now run 'perl zmconfig.pl' to create your ZoneMinder configuration
zmdc.log:
Server starting at 04/08/12 15:40:51
Can't find process with command of 'zmc -d 0'
'zmc -d 0' started at 04/08/12 15:40:55
'zmc -d 0' starting at 04/08/12 15:40:55, pid = 12564
Can't find process with command of 'zma -m 1'
'zmc -d 0' stopping at 04/08/12 15:46:17
'zmc -d 0' died at 04/08/12 15:46:17
'zmc -d 0' started at 04/08/12 15:46:18
'zmc -d 0' starting at 04/08/12 15:46:18, pid = 12813
Can't find process with command of 'zma -m 2'
thnx
Ben
