Page 1 of 1
Color camera won't work (grey ok)
Posted: Sat Aug 14, 2004 12:06 am
by tcolar
Hi, i use zoneminder with a btt48 card (kworld), i use 3 b/w camera and they all work great (320*240)
Now i have a Color cctv camera (lyd-805c), this is a ntsc color 12v 1/4 camera.
I triied it straight on the ntsc tv and it works fine.
Now when i try it on the video card, i do get an image but not a correct one.
I did my test at 320/240.
Anyway, if i set the palette to b/w i do get a decent b/w picture.
if i set to rgb24 i see 3 b/w tiny images
other settings have different results, but none works.
Here are pictures of what i get with different palettes
http://www.colar.net/campb.html
Note: i tried on some other (tested) ports of the card and the results are the same.
Also, i don't think that is a problem, but can you have both b/w and color camera on the card (the card as one chip with switching, 4 channels).
Any ideas what the problem could be (other palette ?, special resolution ?)
Thanks.
Posted: Sat Aug 14, 2004 12:08 am
by victor_diago
increase your shared memory.
i had this before.
Increase it, see in FAQ how.
If that doesnt help, also, increase your swap space with a swap file or swap partition.
victor diago
Posted: Sat Aug 14, 2004 12:13 am
by tcolar
i decreased buffer size to 10 to all my camera, which is suppose to ahve the same effect, also before i would see the out of memory messages, but now i don't so i don't think it's the problem, but i'll try even larger mem to make sure.
Posted: Sat Aug 14, 2004 12:24 am
by tcolar
hum this is wqeir
if i start the color camera alone (zmc -m 7) it works fine.
if i start it with the other cameras (zmc -d 0) then it's broken.
Is mixing b/w and color camera the problem (i hope not).
Thanks.
Posted: Sat Aug 14, 2004 11:07 am
by victor_diago
surely is a SHM (Shared memory) issue.
Go and try to increase It.
Deacrease ring buffer sometimes dont help, specially if you have just a few shm.
Increase it more. i had 190 MB shared memory for 16 cameras, and a ring buffer of 5 (im capturing at 1fps, higher rates, also higher values)
Just try it, i had the same problem, but i've got it working after increase SHM
Victor Diago
Posted: Sat Aug 14, 2004 7:43 pm
by lazyleopard
tcolar wrote:Is mixing b/w and color camera the problem (i hope not).
That will depend in the card you have. If it has a separate bt878 chip for each input then you shouldn't have a problem once you've given the processes sufficient memory. However, if your card has only one bt878 chip, and the different inputs are multiplexed then you need to use the same settings for all the cameras.
