Installed, but...
Posted: Thu Aug 19, 2004 4:24 am
Hi from NZ...
I'm having problems with this Live CD install.
I have setup a new PC: P4, Asus P4P800-VM Mainboard(Intel Chipset 865), 512 MB DDR, 40 GB HDD. Capture Card: Grandtec Xguard 9.
Zoneminder 1.19.1 Live CD installed (with noscsi options).
Problem: Onboard LAN isn't recognised/setup, cannot do it through Mandrake's GUI using the "e100" driver. But it worked in Mandrake 10 official ok, and when running the LiveCD, before install.
The capture card is seen by Mandrake (at least it sees a BT878 card), but doesn't assign it a /dev/video.
What do i do???? I think I could figure out how to build the right files for the LAN if necessary, but I'm thinking there must be something wrong in the compatiblity stakes. (I have installed it fresh twice on this pc to check it)
Help!
Help!
